NFC module not working after rebooting?
Hey guys,
My NFC module (PN532) stops working after I reboot or restart or just turn off then on the Arduino it's connected to. The module lights up and all that but it just won't scan a tag. I don't think the problem is in the code since I've tried many codes and they work up until I reboot the Arduino.
I plugged in an example code (below) and after rebooting the Arduino and checking the serial monitor to see what the Arduino is reading, it stops at ''hello" and won't go anywhere else.
    This example will attempt to connect to an ISO14443A
    card or tag and retrieve some basic information about it
    that can be used to determine what type of card it is.
    Note that you need the baud rate to be 115200 because we need to print
    out the data and read from the card at the same time!
// choose to SPI or I2C or HSU
#if 0
  #include <SPI.h>
  #include <PN532_SPI.h>
  #include "PN532.h"
  PN532_SPI pn532spi(SPI, 10);
  PN532 nfc(pn532spi);
#elif 0
  #include <PN532_HSU.h>
  #include <PN532.h>
  PN532_HSU pn532hsu(Serial1);
  PN532 nfc(pn532hsu);
#else
  #include <Wire.h>
  #include <PN532_I2C.h>
  #include <PN532.h>
  PN532_I2C pn532i2c(Wire);
  PN532 nfc(pn532i2c);
#endif
void setup(void) {
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // Set the max number of retry attempts to read from a card
  // This prevents us from waiting forever for a card, which is
  // the default behaviour of the PN532.
  nfc.setPassiveActivationRetries(0xFF);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A card");
void loop(void) {
  boolean success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, &uid[0], &uidLength);
  if (success) {
    Serial.println("Found a card!");
    Serial.print("UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("UID Value: ");
    for (uint8_t i=0; i < uidLength; i++)
      Serial.print(" 0x");Serial.print(uid[i], HEX);
    Serial.println("");
    // Wait 1 second before continuing
    // PN532 probably timed out waiting for a card
    Serial.println("Timed out waiting for a card");
Thanks
  nfc.begin();
No solution but
  • there can be two calls that block, so put a print statement in between.
  • add a delay(5000) to give the NFC some time to start?
