Hello,
I recently acquired a Nicla Sense Me. I have created an ardunio sketch that sends quaternions via Bluetooth to a browser. I am then applying the quaternion's to a mesh in ThreeJS.
Everything seems to work nicely but I think the orientation is off which I suspect may be the coordinate system? But If there are any suggestions I would be happy to hear them.
I can provide a github repo if needed. (Also added an image with the coordinate system for the bosch component)
Below are the Ardunio and basic web setup
// ARDUNIO EXAMPLE
#include "Arduino.h"
#include "Arduino_BHY2.h"
#include <ArduinoBLE.h>
SensorQuaternion quaternion(SENSOR_ID_RV);
// BLE Service
BLEService imuService("e905de3e-0000-44de-92c4-bb6e04fb0212"); // Custom UUID
// BLE Characteristic
BLECharacteristic imuCharacteristic("917649A1-D98E-11E5-9EEC-0002A5D5C51B", BLERead | BLENotify, 16);
while(!Serial); // Remove when powered by battery
BHY2.begin();
quaternion.begin();
// Setup bluetooth
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
BLE.setAdvertisedService(imuService);
imuService.addCharacteristic(imuCharacteristic);
BLE.addService(imuService);
// start advertising
BLE.advertise();
Serial.println("Bluetooth device active, waiting for connections...");
// wait for a BLE central
BLEDevice central = BLE.central();
// if a BLE central is connected to the peripheral:
if (central) {
Serial.print("Connected to central: ");
// print the central's BT address:
Serial.println(central.address());
// while the central is connected:
while (central.connected()) {
// Update function should be continuously polled
BHY2.update();
Serial.println(String("quaternion: ") + quaternion.toString());
// quaternion
float data[4];
data[0] = quaternion.x();
data[1] = quaternion.y();
data[2] = quaternion.z();
data[3] = quaternion.w();
imuCharacteristic.setValue((byte *) &data, sizeof(data));
Serial.print("Disconnected from central: ");
// WEB EXAMPLE
// Create an empty scene
var scene = new THREE.Scene();
// Create a basic perspective camera
var camera = new THREE.PerspectiveCamera(75, window.innerWidth / window.innerHeight, 0.1, 1000);
camera.position.z = 4;
// Create a renderer with Antialiasing
var renderer = new THREE.WebGLRenderer({ antialias: true });
// Configure renderer clear color
renderer.setClearColor("#000000");
// Configure renderer size
renderer.setSize(window.innerWidth, window.innerHeight);
// Append Renderer to DOM
document.body.appendChild(renderer.domElement);
// Create a Cube Mesh with basic material
var geometry = new THREE.BoxGeometry(1, 1, 1);
var material = new THREE.MeshBasicMaterial({ color: "#433F81" });
var cube = new THREE.Mesh(geometry, material);
// Add cube to Scene
scene.add(cube);
// Render Loop
var render = function () {
requestAnimationFrame(render);
cube.quaternion.set( quaternion[0], quaternion[1], quaternion[2], quaternion[3] );
// Render the scene
renderer.render(scene, camera);
render();
