Nicla voice imu firrmware wont flash
Hi everyone!
I'm having trouble flashing the IMU firmware on my Nicla Voice board. The voice firmware works perfectly, but I can't seem to get the IMU firmware to work. Has anyone else encountered this issue, or does anyone have tips on successfully flashing the IMU firmware? Any help would be greatly appreciated!
Thanks in advance!
the error :
usr@usrusr:~/nicla/arduino-nicla-voice-imu-firmware$ sudo ./flash_linux.sh
Finding Nicla Voice
Finding Nicla Voice OK
Flashing board
Open On-Chip Debugger 0.11.0+dev-gab95bac57-dirty (2021-05-11-10:49)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
debug_level: 0
adapter speed: 1000 kHz
target halted due to debug-request, current mode: Thread
xPSR: 0x01000000 pc: 0x00006654 msp: 0x20010000
** Programming Started **
** Programming Finished **
shutdown command invoked
New upload port: /dev/ttyACM0 (serial)
Flashing done. Use the flash_mac_model.command if you need to update the externah
Please wait target to restart
Flashing synpgk to external flash
Finding Nicla Voice
Updating NN model to flash...
Welcome to ei uploader
Port to use: /dev/ttyACM0
Nicla Voice not answering!
The firmware was successfully uploaded. The problem is that it does not work.
What has voice recognition to do with the IMU?
Have you found any examples on line of reproducible applications with this half-baked, largely unsupported Arduino product? If not, it is probably not worth your effort to pursue.
