Hi all,
I not undestood if SDA and SCL pin nicla voice needs 3.3 or 5v.
Then if I need a level shifter where can I take the reference voltage + for the shifter from Nicla? I dont see
a +3v3 pin and
the pin 7 VDDIO_EXT are 0V
the pin VIN_BQ25120 are 4.8V
Thanks in advance
Paolo
I would help if you posted links to the technical information on the parts we are talking about, there are many with the same or similar descriptions.
Hi gilshultz,
this is the pinout diagram of Nicla Voice, I want to connect it to an Arduino Uno via I2C.
I know the Arduino sends 5V on its port and I don't know if Nicla Voice does the same on the pin 1 and 2 (SCL-SDA).
I think like all recent devices it uses 3v3 and so I need to connect a level shifter, the level shifter needs a low voltage reference and a high voltage reference, for the high voltage I can use the Arduino's 5V but for the low voltage I don't know where to get it because pin 7 on the Nicla is 0V and pin 9 is 4v8 so I don't have 3v3 as a reference.
I'm probably messing around unnecessarily but I don't want to fry the module.
Thanks
Paolo
