I am using an Arduino MKR1000 with the desktop IDE and am having problems with the AnotherIFTTTWebhook.h file.
The code WiFiClient client; is not compiling because there is "no matching function for call to 'WiFiClient::WiFiClient()'".
This code hasn't given me troubles prior to today.
Why is this happening and how do I fix it?
Thanks in advance.
// The MIT License
// Copyright (c) 2015 Neil Webber
// Permission is hereby granted, free of charge, to any person obtaining a copy
// of this software and associated documentation files (the "Software"), to deal
// in the Software without restriction, including without limitation the rights
// to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
// copies of the Software, and to permit persons to whom the Software is
// furnished to do so, subject to the following conditions:
// The above copyright notice and this permission notice shall be included in
// all copies or substantial portions of the Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
// IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
// FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
// AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
// LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
// OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
// THE SOFTWARE.
// An adapted version of IFTTT Trigger by Neil Webber
// Original: https://gist.github.com/outofmbufs/d6ced37b49a484c495f0
// Adaptation from: https://www.siytek.com
// How to use:
// 1. Place AnotherIFTTTWebhook.h in the same directory as your project
// 2. Add #include "AnotherIFTTTWebhook.h" to your main project file
// 3. Send webhook using function in main file:
// send_webhook(EVENT, KEY, Value1, Value2, Value3);
WiFiClient client;
char *append_str(char *here, char *s) {
while (*here++ = *s++)
return here - 1;
char *append_ul(char *here, unsigned long u) {
char buf[20]; // we "just know" this is big enough
return append_str(here, ultoa(u, buf, 10));
void send_webhook(char *MakerIFTTT_Event, char *MakerIFTTT_Key, char *value1, char *value2, char *value3) {
// connect to the Maker event server
client.connect("maker.ifttt.com", 80);
// construct the POST request
char post_rqst[256]; // hand-calculated to be big enough
char *p = post_rqst;
p = append_str(p, "POST /trigger/");
p = append_str(p, MakerIFTTT_Event);
p = append_str(p, "/with/key/");
p = append_str(p, MakerIFTTT_Key);
p = append_str(p, " HTTP/1.1\r\n");
p = append_str(p, "Host: maker.ifttt.com\r\n");
p = append_str(p, "Content-Type: application/json\r\n");
p = append_str(p, "Content-Length: ");
// we need to remember where the content length will go, which is:
char *content_length_here = p;
// it's always two digits, so reserve space for them (the NN)
p = append_str(p, "NN\r\n");
// end of headers
p = append_str(p, "\r\n");
// construct the JSON; remember where we started so we will know len
char *json_start = p;
// As described - this example reports a pin, uptime, and "hello world"
p = append_str(p, "{\"value1\":\"");
p = append_str(p, value1);
p = append_str(p, "\",\"value2\":\"");
p = append_str(p, value2);
p = append_str(p, "\",\"value3\":\"");
p = append_str(p, value3);
p = append_str(p, "\"}");
// go back and fill in the JSON length
// we just know this is at most 2 digits (and need to fill in both)
int i = strlen(json_start);
content_length_here[0] = '0' + (i / 10);
content_length_here[1] = '0' + (i % 10);
// finally we are ready to send the POST to the server!
client.print(post_rqst);
client.stop();
