Windows 10 may HIDE the COM & LPT ports in DEVICE MANAGER.
Unplug the board from the computer.
Make sure that "SHOW HIDDEN DEVICES" is turned on in device mamager.
Plug the board back in.
Does windows make the hardware founf noise ?
If so what does it show in device manager ?
If it was installed correctly then you should have something in the posrts and lpt section.
if NOT then it may show as a device with some form of issue !
Also beware that not all USB3 ports are compatible with Arduino.
Thanks for the reply. This is a difficult time for everybody and your help is greatly appreciated.
The board and cable was working on my PC (Windows 10). I gave it to my brother so he could occupied himself during his confinement. Since I can't go to hi place, I'm tryinh to help me using Any Desk remote application.
He tried to install the board on other USB port, same effect.
The device manager show hidden devices
I did try to install the CH340 drivers many time
Re-installing the IDE would have done little good with these boards.
First are you sure it is aCP2102 based USB device and not a CH340 ?
Installing the driver in SAFE mode was a good move but sometimes you need to install as a FULL ADMINISTRATOR. Note that this is above a "user" with administrative priveledges.
You may also have to turn OFF any additional security for the driver install.
Ensure you are trying all of this on USB 2.0 ports and NOT USB 3.0
Also do not use ESB 3.0 cables at this point.
Ensure you are NOT using cloud based or network based storage unless you fully understand networking and all the services required are running properly.
You say you are running an RDP connection to the other computer.
What type ?
We also need a direct link to the EXACT ESP board you are using to be sure we are on the same page.
