No USB driver for my GIGA R1 board
I'm trying to use my new GIGA board on a 64-bit Windows 7 computer using IDE v1.8.19. After installing the board from the Boards manager, the COM port is not showing up correctly in Windows. The Device Manager shows it as "Other devices / Giga" (with a yellow exclamation mark).
Tried uninstalling/installing a few times, different USB ports, searching for new hardware. Works on a Windows 10 computer, but that's not the one I use in my workshop.
Is there a way to download and install just the driver?
  1. Install IDE 2.0.4 and also install all the dependencies (drivers and libraries) that show up after the installation.
  2. You can then go further to add GIGA pacakge core following Package Core installation (in auto installed, then do do not do this process).
  3. Use a good quality data USB cable to connect the board to the computer. Avoid using USB 3.0 port or USB hub. Charging/bad USB cable will make it impossible for your computer to detect your board.
  4. Make sure you select the board and the port it is connected to before uploading a sketch.
    Note: if this does not work in Windows 7 OS, try using a different computer with Windows 10 OS before doing the last procedure.
  5. If 1-4 above fails to resolve it, then re-burn bootloader to the board following this Burn the bootloader on GIGA R1 WiFi
Hello Dozie, thanks for the reply.
I completed items 1-3 but have not resolved the issue. The Giga board shows INSTALLED int he boards mamager. As I mentioned, the board connected with no issues on my Windows 10 computer, it's just not the one I usually use for coding.
The USB cord is new and of decent quality. Never had any issues.
I can't perform a sketch upload per step 4 as there is no port to select from.
As the board works fine with the Win10 computer, is there any value in (re) burning the bootloader file?
Comment: yes, do not do that step.
Dear @Dozie, i have the same issue. After playing "Inspector Gadget :wink:" probably i think i have found something who explain our problems.
If i check the Vendor ID (VID) and Product ID (PID) over the IDE for my GIGA R1, i found this information: VID:0x2341, PID:0x0266.
BUT! After looking in the .Inf driver file "giga.inf" on newest IDE 2.04, here i found a different PID for the GIGA R1 Board. PID from Board "0x0266", PID from Driver: "0x0366" are not similar!
Probably this is the Problem why Windows 10 cannot handle correct GIGA R1 Board..
Under Windows devicemanager my GIGA R1 Board appears as a microsoft Device an not other Board, like the Micro, as a Arduino Device...
Please look my Screenshoot - I hope you can help us!
Thanks in advance!
weezy
@weezyworks_de What you found out is interesting. Please use the Contact us
form to contact Arduino Tech Support with all the details of the issue and what you found out . It will be looked into in details and solution to the issue found.
It´s DONE! :+1:
@weezyworks_de
Can you share the solution please. So others who experience the same issue can give your solution a try.
@sterretje @KDLaun
At the moment i dont have any solution...
I tried to change the driver file manually to correct PID: 0x0366, but Windows 10 notices the manual change and refuses to install the driver, because the driver signature verification are fault after changing manually.
Yes i know that is possible to disable this "driver signature verification", but i cant do this in my Company! But see the procedure. Maybe you can try it?
https://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
By the way: I contacted the technical support about this issue. I think there will be release a new driver/Board Update.
I'm working on a shed automation project with a friend of mine, I recommended the Arduino GiGA board since i knew it had all the capability, we just received the board and haven't been able to upload anything.
Arduino giga shows up under device manager as giga (other Devices) and no serial port for comms, hopefully Ardunio releases a driver that works for this board soon, we just bought this board and haven't been able to use for anything, its a bit disappointing.
The computer he has in his shed has windows 7 64bit, we talked about the option of upgrading the operating system but he doesn't want to, so that's not an option for us. Please Arduino, help us out!
I just received my Giga R1 boards and have IDE 2.2.1 loaded on my Win10 HP Elitedesk G2 with "Arduino MBed OS Giga Boards" 4.0.6 board manager loaded. I plug in the Giga R1 and get a green LED next to the power connector. I cannot see the port for the Giga R1 in the IDE, and windows Device Manager does not see a COM port when I plug the Giga R1 in like I can see with a Mega. There are no 'issues' in Device Manager. I have tried several brand new USB-A-to-USB-C cables with no change.
Any thoughts?
Hi @mjcother. Please try this experiment and then report back with the results:
  1. Connect your Arduino board to your computer with the USB cable.
  2. Press and release the button marked "RST" on the GIGA R1 WiFi board quickly twice.
  3. If it is already open, close the Tools > Port menu in Arduino IDE.
  4. Open the Tools > Port menu in Arduino IDE.
Now please reply here on the forum thread with the answers to the following questions:
  • Do you now see the LED near the audio socket on the GIGA R1 WiFi board pulsing green?
  • Do you see a port for the board in the Tools > Port menu?
Pressing "RST" twice quickly did nothing, no port for the Giga, and no Boot0 LED, just power LED still solid green...
I have the same exact situation as mjcother
Hi guys, can you share the screenshot of the device manager?
This is on a Windows 11 PC and using the same C cable I use every day to transfer from my phone:
No sign of it:
With a Mega instead:
Screenshot 2023-09-13 065917
This is an HP EliteDesk 800 G1 running win10pro 22h2 19045.3392 that has 2 built in ports(COM1,COM3) and a RobotDyn Mega 2560 Eth board (COM4) that appears when attached and dissappears when detached.
Issue resolved... I held the BOOT0 button for about 5 seconds and the STM32CubeProgrammer was able to see the board and I was able to load the .elf file. After that, the board popped right up.
The IDE sees something there, but the STM32CubeProgrammer doesn't
Uploading "Blink" returns:
Sketch uses 109432 bytes (5%) of program storage space. Maximum is 1966080 bytes.
Global variables use 47512 bytes (9%) of dynamic memory, leaving 476112 bytes for local variables. Maximum is 523624 bytes.
dfu-util 0.10-dev
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2021 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
Device ID 0483:df11
Device DFU version 011a
Claiming USB DFU Interface...
Setting Alternate Interface #0 ...
Determining device status...
DFU state(2) = dfuIDLE, status(0) = No error condition is present
DFU mode device DFU version 011a
Device returned transfer size 1024
DfuSe interface name: "Internal Flash "
Downloading element to address = 0x08040000, size = 111352
Erase [ ] 0% 0 bytes
Erase [= ] 4% 5120 bytes
Erase [== ] 8% 9216 bytes
Erase [=== ] 12% 14336 bytes
Erase [==== ] 16% 18432 bytes
Erase [===== ] 20% 22528 bytes
Erase [====== ] 24% 27648 bytes
Erase [======= ] 28% 31744 bytes
Erase [======== ] 32% 35840 bytes
Erase [========= ] 36% 40960 bytes
Erase [========== ] 40% 45056 bytes
Erase [=========== ] 44% 49152 bytes
Erase [============ ] 48% 54272 bytes
Erase [============= ] 52% 58368 bytes
Erase [============== ] 56% 62464 bytes
Erase [=============== ] 60% 67584 bytes
Erase [================ ] 64% 71680 bytes
Erase [================= ] 68% 75776 bytes
Erase [================== ] 72% 80896 bytes
Erase [=================== ] 76% 84992 bytes
Erase [==================== ] 80% 89088 bytes
Erase [===================== ] 84% 94208 bytes
Erase [====================== ] 88% 98304 bytes
Erase [======================= ] 92% 103424 bytes
Erase [======================== ] 96% 107520 bytes
Erase [=========================] 100% 111352 bytes
Erase done.
Download [ ] 0% 0 bytes
Download [ ] 2% 3072 bytes
Download [= ] 4% 5120 bytes
Download [== ] 8% 9216 bytes
Download [== ] 10% 11264 bytes
Download [=== ] 12% 14336 bytes
Download [==== ] 16% 18432 bytes
Download [==== ] 17% 19456 bytes
Download [===== ] 20% 22528 bytes
Download [====== ] 24% 27648 bytes
Download [======= ] 28% 31744 bytes
Download [======== ] 32% 35840 bytes
Download [========= ] 36% 40960 bytes
Download [========= ] 39% 44032 bytes
Download [========== ] 40% 45056 bytes
Download [=========== ] 44% 49152 bytes
Download [=========== ] 46% 52224 bytes
Download [============ ] 48% 54272 bytes
Download [============= ] 52% 58368 bytes
Download [============= ] 54% 60416 bytes
Download [============== ] 56% 62464 bytes
Download [=============== ] 60% 67584 bytes
Download [=============== ] 61% 68608 bytes
Download [================ ] 64% 71680 bytes
Download [================= ] 68% 75776 bytes
Download [================= ] 68% 76800 bytes
Download [================== ] 72% 80896 bytes
Download [=================== ] 76% 84992 bytes
Download [==================== ] 80% 89088 bytes
Download [==================== ] 83% 93184 bytes
Download [===================== ] 84% 94208 bytes
Download [====================== ] 88% 98304 bytes
Download [====================== ] 91% 101376 bytes
Download [======================= ] 92% 103424 bytes
Download [======================== ] 96% 107520 bytes
Download [======================== ] 98% 109568 bytes
Download [=========================] 100% 111352 bytes
Download done.
File downloaded successfully
Warning: Invalid DFU suffix signature
A valid DFU suffix will be required in a future dfu-util release
Error during download get_status
Failed uploading: uploading error: exit status 74
