NodeMCU v3 ESP8266 is not connected to wifi
Hello all,
I'm running into an issue currently when I try to connect my ESP8266 to my mobile hotspot , my ESP8266 is not connecting to my mobile hotspot
This is my program
#include <BlynkSimpleEsp8266.h>
#include <ESP8266WiFi.h>
#define BLYNK_TEMPLATE_ID "TMPL3On5pdO-u"
#define BLYNK_TEMPLATE_NAME "HOME AUTOMATION"
#define BLYNK_AUTH_TOKEN "1QpA2HJ66oMMAnBSUaTpXLYraqTDIooP"
char ssid[] = "****";
char pass[] = "*********";
bool fetch_blynk_state = true;
#define RelayPin1 5  //D1
#define RelayPin2 4  //D2
#define RelayPin3 14 //D5
#define RelayPin4 12 //D6
#define SwitchPin1 10  //SD3
#define SwitchPin2 0   //D3
#define SwitchPin3 13  //D7
#define SwitchPin4 3   //RX
#define wifiLed   16   //D0
#define VPIN_BUTTON_1    V1
#define VPIN_BUTTON_2    V2
#define VPIN_BUTTON_3    V3
#define VPIN_BUTTON_4    V4
bool toggleState_1 = LOW;
bool toggleState_2 = LOW;
bool toggleState_3 = LOW;
bool toggleState_4 = LOW;
bool SwitchState_1 = LOW;
bool SwitchState_2 = LOW;
bool SwitchState_3 = LOW;
bool SwitchState_4 = LOW;
int wifiFlag = 0;
char auth[] = BLYNK_AUTH_TOKEN;
BLYNK_WRITE(VPIN_BUTTON_1) {
  toggleState_1 = param.asInt();
  digitalWrite(RelayPin1, !toggleState_1);
BLYNK_WRITE(VPIN_BUTTON_2) {
  toggleState_2 = param.asInt();
  digitalWrite(RelayPin2, !toggleState_2);
BLYNK_WRITE(VPIN_BUTTON_3) {
  toggleState_3 = param.asInt();
  digitalWrite(RelayPin3, !toggleState_3);
BLYNK_WRITE(VPIN_BUTTON_4) {
  toggleState_4 = param.asInt();
  digitalWrite(RelayPin4, !toggleState_4);
BLYNK_WRITE(VPIN_BUTTON_C) {
  all_SwitchOff();
void all_SwitchOff() {
  toggleState_1 = 0;
  digitalWrite(RelayPin1, HIGH);
  Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1);
  delay(100);
  toggleState_2 = 0;
  digitalWrite(RelayPin2, HIGH);
  Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2);
  delay(100);
  toggleState_3 = 0;
  digitalWrite(RelayPin3, HIGH);
  Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3);
  delay(100);
  toggleState_4 = 0;
  digitalWrite(RelayPin4, HIGH);
  Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4);
  delay(100);
void manual_control() {
  if (digitalRead(SwitchPin1) == LOW && SwitchState_1 == LOW) {
    digitalWrite(RelayPin1, LOW);
    toggleState_1 = HIGH;
    SwitchState_1 = HIGH;
    Serial.println("Switch-1 on");
  if (digitalRead(SwitchPin1) == HIGH && SwitchState_1 == HIGH) {
    Serial.println("Switch-1 off");
  if (digitalRead(SwitchPin2) == LOW && SwitchState_2 == LOW) {
    digitalWrite(RelayPin2, LOW);
    toggleState_2 = HIGH;
    SwitchState_2 = HIGH;
    Serial.println("Switch-2 on");
  if (digitalRead(SwitchPin2) == HIGH && SwitchState_2 == HIGH) {
    Serial.println("Switch-2 off");
  if (digitalRead(SwitchPin3) == LOW && SwitchState_3 == LOW) {
    digitalWrite(RelayPin3, LOW);
    toggleState_3 = HIGH;
    SwitchState_3 = HIGH;
    Serial.println("Switch-3 on");
  if (digitalRead(SwitchPin3) == HIGH && SwitchState_3 == HIGH) {
    Serial.println("Switch-3 off");
  if (digitalRead(SwitchPin4) == LOW && SwitchState_4 == LOW) {
    digitalWrite(RelayPin4, LOW);
    toggleState_4 = HIGH;
    SwitchState_4 = HIGH;
    Serial.println("Switch-4 on");
  if (digitalRead(SwitchPin4) == HIGH && SwitchState_4 == HIGH) {
    Serial.println("Switch-4 off");
  pinMode(RelayPin1, OUTPUT);
  pinMode(RelayPin2, OUTPUT);
  pinMode(RelayPin3, OUTPUT);
  pinMode(RelayPin4, OUTPUT);
  pinMode(wifiLed, OUTPUT);
  pinMode(SwitchPin1, INPUT_PULLUP);
  pinMode(SwitchPin2, INPUT_PULLUP);
  pinMode(SwitchPin3, INPUT_PULLUP);
  pinMode(SwitchPin4, INPUT_PULLUP);
  //During Starting all Relays should TURN OFF
  digitalWrite(wifiLed, HIGH);
  //Blynk.begin(auth, ssid, pass);
  WiFi.begin(ssid, pass);
  Blynk.config(auth);
  if (!fetch_blynk_state){
  manual_control();
  Blynk.run();
output :
Variables and constants in RAM (global, static), used 29656 / 80192 bytes (36%)
║   SEGMENT  BYTES    DESCRIPTION
╠══ DATA     1552     initialized variables
╠══ RODATA   2176     constants
╚══ BSS      25928    zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 61247 / 65536 bytes (93%)
╠══ ICACHE   32768    reserved space for flash instruction cache
╚══ IRAM     28479    code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 251752 / 1048576 bytes (24%)
╚══ IROM     251752   code in flash
esptool.py v3.0
Serial port /dev/cu.usbserial-1420
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 40:91:51:55:bb:cd
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0340
Compressed 288112 bytes to 210873...
Writing at 0x00000000... (7 %)
Writing at 0x00004000... (15 %)
Writing at 0x00008000... (23 %)
Writing at 0x0000c000... (30 %)
Writing at 0x00010000... (38 %)
Writing at 0x00014000... (46 %)
Writing at 0x00018000... (53 %)
Writing at 0x0001c000... (61 %)
Writing at 0x00020000... (69 %)
Writing at 0x00024000... (76 %)
Writing at 0x00028000... (84 %)
Writing at 0x0002c000... (92 %)
Writing at 0x00030000... (100 %)
Wrote 288112 bytes (210873 compressed) at 0x00000000 in 20.5 seconds (effective 112.7 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
add some Serial.println() statements to your code to give you some idea of the flow of the program and how far it gets, e.g. check WiFi connects
  WiFi.begin(ssid, password);
  // Wait for connection
    Serial.print(".");
  Serial.print("\nConnected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
i have included this in my code, still NodeMCU is not connecting to wifi
it just displays ........................ as it attempts to connect?
are you sure you have a good WiFi signal?
check the SSID and password - try retyping it in case you entered some hidden character - perhaps print it out to make sure it is correct
Variables and constants in RAM (global, static), used 29704 / 80192 bytes (37%)
╠══ RODATA   2216     constants
╚══ BSS      25936    zeroed variables
. Code in flash (default, ICACHE_FLASH_ATTR), used 251976 / 1048576 bytes (24%)
╚══ IROM     251976   code in flash
esptool.py v3.0
Connecting........_
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Compressed 288368 bytes to 211028...
Wrote 288368 bytes (211028 compressed) at 0x00000000 in 20.5 seconds (effective 112.5 kbit/s)...
Leaving...
after this ESP stopped blinking , serial monitor showing ............ like this
if I run your code with the addidion of my code from post 2 with my SSID and password I get
Connected to XXXXXXXXX
IP address: 192.168.1.220
try running File>Examples >ESP8266WiFi>WiFiScan - it should list WiFi in the area
i have tried this , in serial monitor its printing some unknown character like this ⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
looks like you have the incorrect baudrate
Would you mind posting the entire code by which you get connected to WiFi?
in effect your code from post 1 with the WiFi test from post 2
char ssid[] = "xxxxxxx";
char pass[] = "xxxxxxx";
int wifiFlag = 0;
  all_SwitchOff();
  toggleState_1 = 0;
  delay(100);
  toggleState_2 = 0;
  delay(100);
  toggleState_3 = 0;
  delay(100);
  toggleState_4 = 0;
  delay(100);
    Serial.print(".");
  Blynk.config(auth);
  manual_control();
  Blynk.run();
note baudrate is 115200
the WiFi scan displays
Starting WiFi scan...
5 networks found:
  00: [CH 01] [24:A7:DC:96:34:62] -83dBm * V 802.11b/g/n aaaaaa
  01: [CH 04] [74:4A:A4:83:EA:97] -91dBm * V 802.11b/g/n sssssss
  02: [CH 01] [30:B1:B5:32:63:69] -95dBm * V 802.11b/g/n dddddd
  03: [CH 06] [CE:88:26:92:43:9C] -77dBm * V 802.11b/g/n    jjjjjjjjj
  04: [CH 06] [A4:08:F5:AC:68:30] -55dBm * V 802.11b/g/n WPS hzzzzzzz
Still, my serial monitor is showing something like this............. , Do I need to change anything else?
what does the WiFiscan show?
    This sketch demonstrates how to scan WiFi networks.
    The API is almost the same as with the WiFi Shield library,
    the most obvious difference being the different file you need to include:
  Serial.println(F("\nESP8266 WiFi scan example"));
  // Set WiFi to station mode
  WiFi.mode(WIFI_STA);
  // Disconnect from an AP if it was previously connected
  WiFi.disconnect();
  delay(100);
  String ssid;
  int32_t rssi;
  uint8_t encryptionType;
  uint8_t *bssid;
  int32_t channel;
  bool hidden;
  int scanResult;
  Serial.println(F("Starting WiFi scan..."));
  scanResult = WiFi.scanNetworks(/*async=*/false, /*hidden=*/true);
  if (scanResult == 0) {
    Serial.println(F("No networks found"));
  } else if (scanResult > 0) {
    Serial.printf(PSTR("%d networks found:\n"), scanResult);
    // Print unsorted scan results
    for (int8_t i = 0; i < scanResult; i++) {
      WiFi.getNetworkInfo(i, ssid, encryptionType, rssi, bssid, channel, hidden);
      // get extra info
      const bss_info *bssInfo = WiFi.getScanInfoByIndex(i);
      String phyMode;
      const char *wps = "";
      if (bssInfo) {
        phyMode.reserve(12);
        phyMode = F("802.11");
        String slash;
        if (bssInfo->phy_11b) {
          phyMode += 'b';
          slash = '/';
        if (bssInfo->phy_11g) {
          phyMode += slash + 'g';
          slash = '/';
        if (bssInfo->phy_11n) {
          phyMode += slash + 'n';
        if (bssInfo->wps) {
          wps = PSTR("WPS");
      Serial.printf(PSTR("  %02d: [CH %02d] [%02X:%02X:%02X:%02X:%02X:%02X] %ddBm %c %c %-11s %3S %s\n"), i, channel, bssid[0], bssid[1], bssid[2], bssid[3], bssid[4], bssid[5], rssi, (encryptionType == ENC_TYPE_NONE) ? ' ' : '*', hidden ? 'H' : 'V', phyMode.c_str(), wps, ssid.c_str());
      yield();
    Serial.printf(PSTR("WiFi scan error %d"), scanResult);
  // Wait a bit before scanning again
  delay(5000);
Wifi scan showing like this
1 networks found:
  00: [CH 01] [50:2B:73:2B:CA:B1] -90dBm * V 802.11b/g/n     ARAVIND ACT
No networks found
2 networks found:
  00: [CH 01] [36:1E:6B:27:D7:AA] -90dBm * V 802.11b/g/n     AndroidAP55BE
  01: [CH 06] [4C:22:F3:EF:34:3B] -89dBm * V 802.11b/g/n WPS kamakshi
No networks found
2 networks found:
  00: [CH 01] [36:1E:6B:27:D7:AA] -91dBm * V 802.11b/g/n     AndroidAP55BE
  01: [CH 06] [4C:22:F3:EF:34:3B] -88dBm * V 802.11b/g/n WPS kamakshi
is the network you are attempting to connect too in the list
No, so that means the problem is my network, right?
yes, looks like it is not in range??
how far away is the WiFi access point?
can you move into range ?
I am using a mobile hotspot, so it is very near my laptop and ESP.
strange - could the hotspot be 5GHz? the ESP8266 only works with 2.4GHz
I have tried using other wifi, which was showing while I used wifi scan, but when I tried to use that in my code, my serial monitor was printing something like this..... esp not connecting to wifi.
Hello.
You’re using io pin 16 as output. So it’s pulled down as soon as the mcu starts. Either use other pin. Or put some delay before it.
Move the line (pinMode(16,output)) to the bottom of setup() may help.
PS. IO 16 is putting the mcu in flash mode if pulled down, which you do in your code.
