NodeMCU with Key Button Module
I am trying to connect Key Button Module with NodeMCU. The key button module has 3 PINs - VCC, OUT and GND. I connected VCC to 3V3, GND to GND and OUT to D2 of nodemcu. Button purchased here - https://robu.in/product/red-electronic-building-blocks-big-key-button-module-high-level-output/
I have written a small program to blink LED ON/OFF on pressing and releasing a button.
int buttonPin = D2;
int val;
  pinMode(D4, OUTPUT);
  pinMode(buttonPin, INPUT);
  val = digitalRead(buttonPin);
  if (val == LOW) {
    Serial.println(val);
    int count = 0;
    digitalWrite(D4, LOW);
    digitalWrite(D4, HIGH);
When I press and release the button, LED is not blinking. I am not sure what is going wrong in this simple example. Appreciate any help.
Thanks.
Try printing val before testing its value
Does it change if you hold the button in ?
Whatever the problem is, it's not in your code. I loaded it into a handy NodeMCU and as you'd expect, when D2 was grounded, the onboard LED was on, and when D2 was pulled up to 3.3V, it was off.
I added print statements. The value doesn't change on pressing the button.
Thank you for confirming, My nodemcu is working fine, I tried without this button.
Can you measure the voltage between the OUT pin and GND pin of the button when it is pressed and released ?
How have you connected the button to the NodeMCU, directly or via breadboard ? Check all of the connections carefully
