When the noise level is too high the duck will quack.
The electret mic will pick up noise from across the room.
The quacks are randomized in the code, so the length of each quack will be varied, as will the space between the quacks.
I used the same electret mic / op amp set up as this project:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1263440809/0#0
The electret mic requires a special circuit documented on that page.
The code uses the True Random library. It's a bit more random than the normal arduino random function. It is available here: Google Code Archive - Long-term storage for Google Code Project Hosting.
The 'quacking' is a buzzer. RadioShack.com Official Site - America's Technology Store
The op amp to go with the mic is here:SparkFun OpAmp Breakout - LMV358 - BOB-09816 - SparkFun Electronics
The arduino and buzzer were sewn inside the beanie baby duck.
#include <TrueRandom.h>
//This uses the TrueRandom Library
int speaker = 9; //the piezo buzzer on pin 9
int tone = 1500;
int sensorPin = 4; //Microphone Sensor Pin
int sensorValue = 0;
long unsigned present = 0;
long unsigned past = 0;
int RandomQuack = 0;
int RandomRest = 0;
int VarQuack = 0;
int VarRest = 0;
Quack = 200
quick = 100
with a 100 space between
void setup () {
pinMode (speaker, OUTPUT);
void loop ()
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
if (sensorValue<509){ // if the noise level is high
VarQuack = TrueRandom.random(0,2); // assign a Random Quack
if (VarQuack == 0){ // it will be either 100 or 200 in duration
RandomQuack = 100;
Serial.println("short Quack");
RandomQuack = 250;
Serial.println("Quack");
VarRest = TrueRandom.random(0,2); // assign a Random Rest time between quacks
if (VarRest == 0){ // it will be 50 or 100
RandomRest = 50;
RandomRest = 100;
past = millis();
do{ // QUACK do/while loop
present = millis();
digitalWrite (speaker, HIGH);
delayMicroseconds (tone / 2);
digitalWrite (speaker, LOW);
tone = 1500;
tone = map(tone, 0, 1023, 1000, 5000);
} while (present - past < RandomQuack); // a random QUACK duration
delay (RandomRest); // random delay between Quacks
// assign Random Values again
RandomQuack = 100;
RandomQuack = 200;
RandomRest = 50;
RandomRest = 100;
past = millis();
do{ // second random quack
present = millis();
tone = 1500;
} while (present - past < RandomQuack); // another random quack duration
delay (RandomRest); // delay between quack
RandomQuack = 100;
Serial.println(" ");
RandomQuack = 200;
RandomRest = 50;
RandomRest = 100;
past = millis();
do{ // Third random quack
present = millis();
tone = 1500;
delay (RandomRest);
digitalWrite(speaker, LOW);
