Serial monitor displays characters while executing sample code from various #include examples for this device.
The specific unit that I am using is
Connections are:
DS3231 '+' goes to 5V on Mega
DS3231 'D' goes to SDA (pin 20) on Mega
DS3231 'C' goes to SCA (pin 21) on Mega
DS3231 'NC' not used
DS3231 '-' goes to GND on Mega
The
The code is
#include <Wire.h>
#include <RealTimeClockDS3231.h>
#define Display_Clock_Every_N_Seconds 1
#define Display_ShortHelp_Every_N_Seconds 25
int count=0;
char formatted[] = "00-00-00 00:00:00x";
// Wire.begin();
if(Serial.available())
processCommand();
RTC.readClock();
count++;
if(count % Display_Clock_Every_N_Seconds == 0){
Serial.print(count);
Serial.print(": ");
RTC.getFormatted(formatted);
Serial.print(formatted);
if(count % Display_ShortHelp_Every_N_Seconds == 0) {
Serial.println("Send ? for a list of commands.");
#ifdef TEST_1224Switch
if(count%10 == 0)
if(count %20 == 0)
Serial.println("switching to 12-hour time");
RTC.switchTo12h();
RTC.setClock();
Serial.println("switching to 24-hour time");
RTC.switchTo24h();
RTC.setClock();
#endif
void processCommand() {
if(!Serial.available()) { return; }
char command = Serial.read();
int in,in2;
switch(command)
case 'H':
case 'h':
in=SerialReadPosInt();
RTC.setHours(in);
RTC.setClock();
Serial.print("Setting hours to ");
Serial.println(in);
case 'I':
case 'i':
RTC.setMinutes(in);
RTC.setClock();
Serial.print("Setting minutes to ");
Serial.println(in);
case 'S':
case 's':
RTC.setSeconds(in);
RTC.setClock();
Serial.print("Setting seconds to ");
Serial.println(in);
case 'Y':
case 'y':
RTC.setYear(in);
RTC.setClock();
Serial.print("Setting year to ");
Serial.println(in);
case 'M':
case 'm':
RTC.setMonth(in);
RTC.setClock();
Serial.print("Setting month to ");
Serial.println(in);
case 'D':
case 'd':
RTC.setDate(in);
RTC.setClock();
Serial.print("Setting date to ");
Serial.println(in);
case 'W':
Serial.print("Day of week is ");
Serial.println((int) RTC.getDayOfWeek());
case 'w':
RTC.setDayOfWeek(in);
RTC.setClock();
Serial.print("Setting day of week to ");
Serial.println(in);
case 't':
case 'T':
if(RTC.is12hour()) {
RTC.switchTo24h();
Serial.println("Switching to 24-hour clock.");
RTC.switchTo12h();
Serial.println("Switching to 12-hour clock.");
RTC.setClock();
case 'A':
case 'a':
RTC.setAM();
RTC.setClock();
Serial.println("Set AM.");
Serial.println("(Set hours only in 24-hour mode.)");
case 'P':
case 'p':
RTC.setPM();
RTC.setClock();
Serial.println("Set PM.");
case '>':
in2=SerialReadPosInt();
RTC.writeData(in, in2);
Serial.print("Write to register ");
Serial.print(in);
Serial.print(" the value ");
Serial.println(in2);
case '<':
in2=RTC.readData(in);
Serial.print("Read from register ");
Serial.print(in);
default:
Serial.println("Unknown command. Try these:");
Serial.println(" h## - set Hours d## - set Date");
Serial.println(" i## - set mInutes m## - set Month");
Serial.println(" s## - set Seconds y## - set Year");
Serial.println(" w## - set arbitrary day of Week");
Serial.println(" t - toggle 24-hour mode");
Serial.println(" a - set AM p - set PM");
Serial.println(" z - start clock Z - stop clock");
Serial.println(" q - SQW/OUT = 1Hz Q - stop SQW/OUT");
Serial.println(" >##,### - write to register ## the value ###");
Serial.println(" <## - read the value in register ##");
}//switch on command
//read in numeric characters until something else
//or no more data is available on serial.
int SerialReadPosInt() {
int i = 0;
boolean done=false;
while(Serial.available() && !done)
char c = Serial.read();
if (c >= '0' && c <='9')
i = i * 10 + (c-'0');
done = true;
return i;
I have tested this on a genuine Arduino Mega 2560 and on an Elegoo Mega 2560. Both units successfully run other sketch's (data logger using DS18B20 temp sensors, SD card shield etc.).
I have also tried two different DS3231 devices.
Any assistance is greatly appreciated.
Best regards,
Daryl
