About to attempt my project this weekend
Using the motor shield the connections are basic that’s no problem
My issue is connection to the analog pins or any other pins that the shield connects to the Arduino to.
If I say use Analog A1, as pictured, do I solder my connection to the A1 “blob” of solder currently in that input? Sorry it’s a stupid noob question. Also , what are -“” the non soldered open connections right above it? There’s about 18 of them?
Yes, You can solder a wire the the blob. I advice You to have the shield plugged into the controller in order to keep the pin in the proper position.
That is an economy design of the shield. Some shields at least provide a pin pointing up on the shield, to connect to.
so i can use either hole or use the empty one, or use the one with solde already in it? sorry for the noob questions i am just new learning this board and first project ahead.
im not using breadboard connections just an audio line coming to it
thank you in advance!!
