Hey everyone,
I am new to and learning electronic stuff and loving messing with my arduino.
I am sure there is a way to connect multiple LEDs that are on at the same time and not have them get more and more dim as you add another LED.
How do I do that?
Thanks in advance
Each LED needs it own current limiting resistor... or what you see... happens.
Remember each Arduino pin can only provide 40mA - or about 2 LED's worth at 20mA per LED.
If you need more LEDs than that controlled from one pin, you will need to use a transistor to drive the LEDs.
Do some research, paste us a schematic diagram of what you think you want to make, and we will tell you if it will work.
There are two ways to wire LED's together:
- If you put the LED's in parallel you need a current limiting resistor for each one.
- If you put the LED's in series you have to add up their voltage drops before calculating the single current limiting resistor.
If you put more than 2 or 3 LED's in series you will need more then 5V to drive them.
system
5
