I also have the "Error: {"err":"Unauthorized","reason":"subject error: request is not whitelisted"}" in my web console.
Does the fault still occur if you start Firefox in "troubleshoot mode" and then try to view the code?:
https://support.mozilla.org/kb/diagnose-firefox-issues-using-troubleshoot-mode
yes. response performance is going down, but the code is still not loading.
@ thread owner:
markba633csi - when you want your problem getting solved, please provide the information as requested from @ptillisch - my only purpose was to confirm that your problem effects also other users.
I will now go into silent mode.
Based on the replies here it looks to me like there isn't a single cause. May be Arduino's edge/CDN has inconsistent behavior across different nodes or different loads. The HTTP/3 mishandling might be one failure mode (and the fix that worked for me) that happens to route through their whitelist check, while you are hitting a different failure path that just so happens to produce the identical wavy lines.
Those wavy lines are Arduino's generic "still waiting on data" state regardless of why the data's never arrived.
As others mentioned the IDE's built-in examples or using some Chromium implementation is easier than chasing this forever.
My browser and/or OS is too old and lame LOL
I'm just going to keep coding and not worry about it
I actually realized that writing code is like grabbing a bunch of components and
soldering/breadboarding them together to make something new
If one knows a bit of analog electronics it helps with the thought process
code salad?
