Not able to view code snippets in built-in examples
None of them are visible- only some
wispy horizontal lines- why?- apparently many others have or had this issue also
going back several years
Hi @markba633csi. I'm not sure I understand what you mean by this.
Where exactly are you viewing the examples?
Are you looking at them on a web page? If so, please provide a link to one of the pages that has this problem.
Or are you instead looking at them in one of the Arduino development tools? If so, please tell us which specific tool.
Adding to above reply, if you're using one of the IDEs your operating system might be relevant as well.
Please provide a link to one or more of them.
Show a screenshot of what you are referring to as I have never heard of this now or going back several years. Here are some screenshots of my examples.
These are in the Arduino online documentation in the programming section
I can see all the other material (pictorial of breadboard, etc) but not the example code in the box
I'll put a link to one of them
https://docs.arduino.cc/built-in-examples/digital/Button/
I'm using a linux distro on a Thinkpad T400- Firefox
Maybe the popup blocker doing it? I'll try turning it off...Nope, still can't view it
Well, need to run out for a bit- I shall return shortly
Please post a link to a page that shows the problem
Which Operating System and browser are you using ?
I see the same thing (Linux Debian 13.6, Firefox 150.0.3, addblock and noscript disabled). Instead of the code snippets, I see multiple bars that look like progress bars that keep restarting.
In Chromium 150.0.7871.181, the snippets render just fine.
Looks ok to me on my Mac (BSD Unix)
Open a separate browser tab.
Type about:config in the URL bar.
Search for network.http.http3.enable
Set it to false. Restart Firefox and reload the Arduino example page.
No (real) problems here with Firefox on either Win11 or Manjaro Linux. I can see the bars mentioned in post #7 for a short while (in Windows 2-3 seconds, Manjaro 5-7 seconds), after that the code shows.
In Windows I use NoScript and AdBlock Plus; in Manjaro I don´t use them and it runs on an old external HD (USB).
I haven´t looked at the "why¨; the page might be fetching info from another site (maybe github).
PS
network.http.http3.enable is set to true on both systems.
It is utilizing the Arduino Cloud Editor infrastructure for the embed:
I haven't use FF in years but I installed both the Snap and official Debian release. No extensions. (Ubuntu 24). Got the wavy lines in each one in the code section of the page. After many fruitless attempts I landed on network.http.http3.enable as there 304 errors loading the Roboto font in the code section of the page (this is a side effecy, not the cause.)As near as I can tell Firefox makes requests to Arduino’s backend (app.arduino.cc) over HTTP/3 (QUIC), and Arduino’s server/CDN was rejecting those specific requests with a “not whitelisted” error... possibly a bug in how their infrastructure validates HTTP/3 traffic? This is just a guess. Toggling the flag it falls back to HTTP/2 and loads fine.
I can toggle http3.enable on/off and the reloaded page will or will not show the code depending on the toggle.
Firefox 153.0.3 32bit portable:
have deactivated http3 (network.http.http3.enable = false), restarted firefox but the code is still not showing.
deactivated the blocker, the code is still not showing
What happens if you open the URL directly in your browser?:
https://create.arduino.cc/example/builtin/02.Digital\Button/Button/preview?embed&snippet
When I do this, it redirects to the following URL:
https://app.arduino.cc/sketches/examples?view-mode=snippet&eid=02.Digital%2FButton
which displays the example sketch content, just as expected.
Note that, although we must be logged into an arduino.cc account in order to use Arduino Cloud Editor to develop sketches, the "snippet view mode" works without any authentication. So even though the Cloud Editor infrastructure is being leveraged, the visibility of the code is not dependent on an Arduino account and all readers of the documentation should be able to see this.
first link gets forwarded to second link, but shows only the "loading" columns
Do you see anything of interest if you open the Firefox web console, then reload the https://app.arduino.cc/sketches/examples?view-mode=snippet&eid=02.Digital%2FButton page?
  1. Click the ≡ icon near the top right hand corner of the Firefox window.
    A menu will open.
  2. Select More Tools > Web Developer Tools from the menu.
    The web developer tools panel will open in the Firefox window.
  3. Select the "Console" tab in the web developer tools panel.
  4. If you already have the page for the "Button" example sketch open in the browser, reload the page. Otherwise, open that page.
You should now see some output appear in the web developer tools panel. Examine that output to see if you spot anything of interest. Unfortunately, I see some errors even on my system, where the code loads without any problem. So a given error in the console may be an irrelevant "red herring".
The code in the window shows up fine for me when I linked from the forum BUT when I opened a new tab, copied the link you gave and used that, the code don't load and I get what you described.
Try using the link in your earlier post?
Anyway besides that, IDE 1.8.x has examples loaded with no online xfers necessary. Use your IDE.
some 404, some 401, some css warnings
but one larger .js error (?)
GET
https://app.arduino.cc/sketches/examples?view-mode=snippet&eid=02.Digital/Button
[HTTP/2 404  758ms]
GET
https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js
[HTTP/2 200  82ms]
GET
https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js
[HTTP/2 200  62ms]
GET
https://app.arduino.cc/sketches/assets/a-split-ly2CZQz-.js
[HTTP/2 200  50ms]
GET
https://app.arduino.cc/sketches/assets/index-Q-oeufFq.css
[HTTP/2 200  82ms]
Unbekannte Pseudoklasse oder Pseudoelement '-ms-reveal'.  Regelsatz wegen ungĂĽltigem Selektor ignoriert. index-Q-oeufFq.css:1:22793
Farbe erwartet, aber 'shared-var' gefunden.  Fehler beim Verarbeiten des Wertes fĂĽr 'color'.  Deklaration ignoriert. index-Q-oeufFq.css:1:24654
Fehler beim Verarbeiten des Wertes fĂĽr 'width'.  Deklaration ignoriert. index-Q-oeufFq.css:1:71584
Fehler beim Verarbeiten des Wertes fĂĽr 'width'.  Deklaration ignoriert. index-Q-oeufFq.css:1:75405
Fehler beim Verarbeiten des Wertes fĂĽr 'height'.  Deklaration ignoriert. index-Q-oeufFq.css:1:102943
Fehler beim Verarbeiten des Wertes fĂĽr 'height'.  Deklaration ignoriert. index-Q-oeufFq.css:1:103557
Fehler beim Verarbeiten des Wertes fĂĽr 'width'.  Deklaration ignoriert. index-Q-oeufFq.css:1:147987
Unbekannte Eigenschaft '-moz-osx-font-smoothing'.  Deklaration ignoriert. index-Q-oeufFq.css:1:218630
Fehler beim Verarbeiten des Wertes fĂĽr '-webkit-text-size-adjust'.  Deklaration ignoriert. index-Q-oeufFq.css:1:218665
Farbe erwartet, aber 'none' gefunden.  Fehler beim Verarbeiten des Wertes fĂĽr 'background-color'.  Deklaration ignoriert. index-Q-oeufFq.css:1:231210
Unbekannte Pseudoklasse oder Pseudoelement 'export'.  Regelsatz wegen ungĂĽltigem Selektor ignoriert. index-Q-oeufFq.css:1:262393
Unbekannte Pseudoklasse oder Pseudoelement 'export'.  Regelsatz wegen ungĂĽltigem Selektor ignoriert. index-Q-oeufFq.css:1:262451
Fehler beim Verarbeiten des Wertes fĂĽr 'width'.  Deklaration ignoriert. index-Q-oeufFq.css:1:343948
Unbekannte Eigenschaft 'line-clamp'.  Deklaration ignoriert. index-Q-oeufFq.css:1:376561
Unbekannte Eigenschaft 'interpolate-size'.  Deklaration ignoriert. index-Q-oeufFq.css:1:415209
Fehler beim Verarbeiten des Wertes fĂĽr 'transition'.  Deklaration ignoriert. index-Q-oeufFq.css:1:417574
Fehler beim Verarbeiten des Wertes fĂĽr 'width'.  Deklaration ignoriert. 3 examples:1:7
GET
https://app.arduino.cc/sketches/assets/matchCounter-CaM7oBAG.js
[HTTP/2 200  64ms]
GET
https://app.arduino.cc/sketches/assets/MainPage-DzdgcRAs.js
[HTTP/2 200  56ms]
GET
https://app.arduino.cc/sketches/assets/hotjar-B_Y8RlGJ.js
[HTTP/2 200  57ms]
GET
https://app.arduino.cc/sketches/assets/MainPage-ajWpzQ1o.css
[HTTP/2 200  72ms]
GET
https://app.arduino.cc/favicon.ico
[HTTP/2 404  42ms]
GET
https://static.hotjar.com/c/hotjar-1036685.js?sv=6
[HTTP/2 200  56ms]
GET
https://status.arduino.cc/embed/script.js
[HTTP/2 200  32ms]
GET
https://app.arduino.cc/sketches/assets/keywords-D6thjXxv.js
[HTTP/2 200  32ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples
[HTTP/2 200  137ms]
XHR GET
https://status.arduino.cc/api/v2/status.json
[HTTP/2 200  51ms]
XHR POST
https://api2.arduino.cc/genai/v2/examples/02.Digital/Button/conversation
[HTTP/2 401  333ms]
GET
https://login.arduino.cc/authorize?client_id=UXHum9nv7XkpETMpm6Pi4Tg2FpoPpmhW&scope=openid+profile+email&redirect_uri=https://app.arduino.cc/sketches/redirect&logout_uri=https://app.arduino.cc/sketches&audience=https://api.arduino.cc&state=d0l1UWpLd3lxWlhoNC1nUzIzSFE0T1Z5Sy5OUS14djVETXJIaE9NcndhUg==&prompt=none&response_type=code&response_mode=web_message&nonce=czRlSnJ0Ni1MbVlLTGkyeDd4dk1lSUZGbm91VlNQMVRMREZKcnFxb3EwSQ==&code_challenge=nNRH13AXKbs6Mu-_jXw-G5GlnvzDOYT5Z9OCtMcyreI&code_challenge_method=S256&auth0Client=eyJuYW1lIjoiYXV0aDAtc3BhLWpzIiwidmVyc2lvbiI6IjIuMTYuMCJ9
[HTTP/2 200  239ms]
GET
https://xsvbyz24zfjk.statuspage.io/embed/frame
[HTTP/2 200  61ms]
GET
data:image/svg+xml,%3csvg%20width='15'%20height='8'%20viewBox='0%200%2015%208'%20fill='none'%20xmlns='http://www.w3.org/2000/svg'%3e%3cpath%20fill-rule='evenodd'%20clip-rule='evenodd'%20d='M7.5%204.97755C8.35464%206.46437%209.6849%207.28125%2011.2596%207.28125C13.0637%207.28125%2014.5312%205.80931%2014.5312%204C14.5312%202.19069%2013.0637%200.71875%2011.2596%200.71875C9.6849%200.71875%208.35464%201.53563%207.5%203.02245C6.64536%201.53563%205.3151%200.71875%203.74039%200.71875C1.93634%200.71875%200.46875%202.19069%200.46875%204C0.46875%205.80931%201.93634%207.28125%203.74039%207.28125C5.3151%207.28125%206.64536%206.46437%207.5%204.97755ZM8.25531%204.40741L8.03353%204L8.25531%203.59259C8.9447%202.32573%209.98337%201.65625%2011.2596%201.65625C12.5466%201.65625%2013.5938%202.70773%2013.5938%204C13.5938%205.29227%2012.5466%206.34375%2011.2596%206.34375C9.98337%206.34375%208.9447%205.67427%208.25531%204.40741ZM1.40625%204C1.40625%202.70773%202.45338%201.65625%203.74039%201.65625C5.01663%201.65625%206.0553%202.32573%206.74469%203.59259L6.96647%204L6.74469%204.40741C6.0553%205.67427%205.01663%206.34375%203.74039%206.34375C2.45339%206.34375%201.40625%205.29227%201.40625%204ZM11.3688%204.35175H12.0849V3.66663H11.3688V2.94565H10.684V3.66663H9.96693V4.35175H10.684V5.07273H11.3688V4.35175ZM5.013%203.66663H2.89407V4.35175H5.013V3.66663Z'%20fill='white'/%3e%3c/svg%3e
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/BlinkWithoutDelay
[HTTP/2 200  461ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/Debounce
[HTTP/2 200  366ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/Button
[HTTP/2 200  339ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/DigitalInputPullup
[HTTP/2 200  366ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/toneKeyboard
[HTTP/2 200  489ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/StateChangeDetection
[HTTP/2 200  489ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/toneMelody
[HTTP/2 200  488ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/tonePitchFollower
[HTTP/2 200  489ms]
XHR GET
https://api2.arduino.cc/libraries/v1/builtin/examples/02.Digital/toneMultiple
[HTTP/2 200  181ms]
Error: {"err":"Unauthorized","reason":"subject error: request is not whitelisted"}
    FH https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:14
    b https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:14
    promise callback*u1e https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:14
    fetch https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:15
    post https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:15
    Z8 https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:15
    yu https://app.arduino.cc/sketches/assets/MainPage-DzdgcRAs.js:7
    py https://app.arduino.cc/sketches/assets/MainPage-DzdgcRAs.js:56
    gy https://app.arduino.cc/sketches/assets/MainPage-DzdgcRAs.js:56
    <anonymous> https://app.arduino.cc/sketches/assets/MainPage-DzdgcRAs.js:67
    c https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    p https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    Fee https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    fetch https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    executeFetch https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    onSubscribe https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    subscribe https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    Bnt https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    y9 https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:38
    Dh https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:40
    Du https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:40
    RK https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:40
    rs https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:40
    xS https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:40
    Fi https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:38
    Rr https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:40
    Fa https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:40
    x9 https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:38
    a https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    n https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    s https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    r https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    promise callback*lB https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    i https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    dispatch https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    setData https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    onSuccess https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    d https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    promise callback*p https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:532
    P https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:25
    V https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:25
    EventHandlerNonNull* https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:25
    <anonymous> https://app.arduino.cc/sketches/assets/b-split-DbxSRNtr.js:25
    CAUSE: u1e https://app.arduino.cc/sketches/assets/index-wU_p5yJ5.js:14
Caused by: Error:
index-wU_p5yJ5.js:15:5012
FĂĽr "https://xsvbyz24zfjk.statuspage.io/embed/frame" wurde partitionierter Cookie- oder Speicherzugriff verwendet, da es im Kontext eines Drittanbieters geladen wurde und dynamische Zustandspartitionierung aktiv ist. content.js:18:85653
GET
https://script.hotjar.com/modules.75bf3488a101739acfe9.js
[HTTP/2 200  35ms]
