Not declared in scope
Need help it keeps saying 'not declared in scope' and I am lost at this point, I,ve tried everything to fix it and nothings working
Robot Demo - Example 2
Drive in specific pattern using line counting navigation
// SparkFun RedBot Library
#include <RedBot.h>
// create objects using classes in RedBot library
RedBotButton button;
RedBotMotors motors;
RedBotEncoder encoder(A2, 10);
RedBotSensor leftLine(A3);
RedBotSensor centerLine(A6);
RedBotSensor rightLine(A7);
// global variables for buzzer and LED pin numbers
const int buzzer = 9;
const int led = 13;
// global variables to keep track of which scenario to demonstrate
int scenario = 1;
boolean started = false;
pinMode(buzzer, OUTPUT);
pinMode(led, OUTPUT);
checkButton();
if (started == true) {
if (scenario == 1) scenario1();
else if (scenario == 2) scenario2();
else if (scenario == 3) scenario3();
const int followCountLine();
// CUSTOM FUNCTIONS
void scenario1() {
// Scenario 1: Drive from kitchen to Table 2, drive around table, and return to start
// drive from Start line to Table 2 line
followCountLine(2); // 2nd line will be path to Table 2
pivotAngle(-90); // pivot -90 angle = turn left
followCountLine(1); // next line is the circle around table
pivotAngle(-90);
alertSound(); // food is here!
followCountLine(1); // drive once around table
// turn and return to kitchen
pivotAngle(-90);
followCountLine(1); // next line is main path
pivotAngle(-90);
followCountLine(1); // next line is Start
alertSound(); // robot is ready for next order!
// set global variables for next scenario
scenario = 2;
started = false;
void scenario2() {
// add code for Scenario 2
scenario = 3;
started = false;
pivotAngle(-90);
pivotAngle(-90);
pivotAngle(-90);
scenario = 2;
started = false;
void scenario3() {
// add code for Scenario 3
// reset global variables for 1st scenario
scenario = 1;
started = false;
void checkButton() {
// add code for this custom function
void alertSound() {
Serial.print(left.read());
Serial.print("\t"); // tab character
Serial.print(center.read());
Serial.print(right.read());
if((left.read() > LINETHRESHOLD) && (center.read() > LINETHRESHOLD) && (right.read() > LINETHRESHOLD) )
motors.brake();
playNote(noteA3, WN);
delay(3000);
motors.leftMotor(leftSpeed);
motors.rightMotor(rightSpeed);
delay(200);
void followLine() {
void followCountLine(int target) {
void driveDistance(float distance, int power) {
void pivotAngle(float angle) {
The compiler says a LOT more than that. It says WHAT is not declared in this scope AND it points to where the scope is that the variable is not declared in.
Count your curly braces. The number of { must match the number of }. Yours do NOT match.
What an odd place to put a function prototype.
Inaccurate too.
Kayperkins19:
Sometimes the first error is not the most important. I fixed a few and there are plenty left. Look at all of the messages and solve the ones you can. Sometimes that will magically fix the first error.
//  Robot Demo - Example 2
//  Drive in specific pattern using line counting navigation
#include <RedBot.h>
const int LINETHRESHOLD = 300; // UNDEFINED?!?
const int led = 13;
int scenario = 1;
  checkButton();
    if (scenario == 1)
      scenario1();
      scenario2();
      scenario3();
// CUSTOM FUNCTIONS
void scenario1() {
  pivotAngle(-90);
  pivotAngle(-90);
  pivotAngle(-90);
  scenario = 2;
  started = false;
void scenario2() {
  scenario = 3;
  started = false;
  pivotAngle(-90);
  pivotAngle(-90);
  pivotAngle(-90);
  scenario = 2;
  started = false;
void scenario3() {
  scenario = 1;
  started = false;
void alertSound() {
  Serial.print(leftLine.read());
  Serial.print(centerLine.read());
  Serial.print(rightLine.read());
  if ((leftLine.read() > LINETHRESHOLD) &&
      (centerLine.read() > LINETHRESHOLD) &&
      (rightLine.read() > LINETHRESHOLD) )
    motors.brake();
    delay(3000);
    delay(200);
void followLine() {
Even with those fixed I'm still getting plenty of errors (and warnings, since I have my warning level set to ALL).
/Users/john/Documents/Arduino/sketch_dec10a/sketch_dec10a.ino: In function 'void loop()':
/Users/john/Documents/Arduino/sketch_dec10a/sketch_dec10a.ino:39:31: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
/Users/john/Documents/Arduino/sketch_dec10a/sketch_dec10a.ino: In function 'void alertSound()':
sketch_dec10a:120: error: 'noteA3' was not declared in this scope
sketch_dec10a:120: error: 'WN' was not declared in this scope
sketch_dec10a:120: error: 'playNote' was not declared in this scope
sketch_dec10a:122: error: 'leftSpeed' was not declared in this scope
sketch_dec10a:123: error: 'rightSpeed' was not declared in this scope
sketch_dec10a:128: error: 'leftSpeed' was not declared in this scope
sketch_dec10a:129: error: 'rightSpeed' was not declared in this scope
/Users/john/Documents/Arduino/sketch_dec10a/sketch_dec10a.ino: At global scope:
/Users/john/Documents/Arduino/sketch_dec10a/sketch_dec10a.ino:137:26: warning: unused parameter 'target' [-Wunused-parameter]
/Users/john/Documents/Arduino/sketch_dec10a/sketch_dec10a.ino:141:26: warning: unused parameter 'distance' [-Wunused-parameter]
/Users/john/Documents/Arduino/sketch_dec10a/sketch_dec10a.ino:141:40: warning: unused parameter 'power' [-Wunused-parameter]
/Users/john/Documents/Arduino/sketch_dec10a/sketch_dec10a.ino:145:23: warning: unused parameter 'angle' [-Wunused-parameter]
exit status 1
