since you're checking for serial input, just once in setup, what happens if there's not serial data at that time? what gets printed if there's no serial data
gcjr:
Even when it's put into void loop(), the same thing happens (zero indefinitely).
gcjr:
does the tx pin need to be configured as an OUTPUT?
see SoftwareSerial:
Ough, thanks for the suggestion! Although, I tried that just now, and it did not make a difference. I'm keeping it in though. I think that's the correct way from the link.
Both the sending and receiving Arduino needed pinMode defined:
This makes no sense given the source code for SoftwareSerial.h. I see both pins set to the correct pinMode in the library for the AVR boards like the UNO, Nano, etc.
void SoftwareSerial::setTX(uint8_t tx)
// First write, then set output. If we do this the other way around,
// the pin would be output low for a short while before switching to
// output high. Now, it is input with pullup for a short while, which
// is fine. With inverse logic, either order is fine.
digitalWrite(tx, _inverse_logic ? LOW : HIGH);
pinMode(tx, OUTPUT);
_transmitBitMask = digitalPinToBitMask(tx);
uint8_t port = digitalPinToPort(tx);
_transmitPortRegister = portOutputRegister(port);
void SoftwareSerial::setRX(uint8_t rx)
pinMode(rx, INPUT);
if (!_inverse_logic)
digitalWrite(rx, HIGH); // pullup for normal logic!
_receivePin = rx;
_receiveBitMask = digitalPinToBitMask(rx);
uint8_t port = digitalPinToPort(rx);
_receivePortRegister = portInputRegister(port);
