[SOLVED] SoftwareSerial simple message
Hi, i have two arduino connected to each other. Arduino one pin 10 RX to pin 11 TX on other arduino and vice versa. I have this simple "hi" message sending every second 1 second from arduino one to arduino two. But nothing is showing. Here are the two codes.
Sender:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  while (!Serial) {
  mySerial.begin(9600);
void loop() // run over and over
  mySerial.write("hi");
  delay (1000);
Receiver:
  while (!Serial) {
  if (mySerial.available())
    mySerial.println();
Did you connect the grounds?
What do you expect this to print?
PS: check out this
is this better?
SoftwareSerial mySerial =  SoftwareSerial(10, 11);
char rd;
void setup()  {
    while (!mySerial)
        rd=mySerial.read();
        mySerial.print(rd);
not at first, then i changed the code and still nothing
Where do you expect to see the output of this action to appear?
mySerial.print(rd);
I have the impression that you aren't very carefully thinking this through.
Take a look at this code, which echos the serial data obtained from a GPS module to the serial monitor:
SoftwareSerial mySerial(10, 11); //GPS (RX, TX) check correct pin assignments and baud rate
  Serial.println("GPS start");
  while (mySerial.available()) {
    Serial.write(mySerial.read());
awesome! thanks
