I am using Arduino UNO with a MAX485 module to interface the NPK sensor which supports 12 v to 24v.
Below is the Arduino script I am applying to get the output value of NPK
#include <AltSoftSerial.h>
// RO to pin 8 & DI to pin 9 when using AltSoftSerial
#define RE 6
#define DE 7
const byte nitro[] = {0x01, 0x03, 0x00, 0x1e, 0x00, 0x01, 0xe4, 0x0c};
const byte phos[] = {0x01, 0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
const byte pota[] = {0x01, 0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
byte values[11];
AltSoftSerial mod;
mod.begin(9600);
pinMode(RE, OUTPUT);
pinMode(DE, OUTPUT);
// put RS-485 into receive mode
digitalWrite(DE, LOW);
digitalWrite(RE, LOW);
delay(3000);
byte val1, val2, val3;
Serial.print("Nitrogen: ");
val1 = nitrogen();
Serial.print(" = ");
Serial.print(val1);
Serial.println(" mg/kg");
delay(250);
Serial.print("Phosphorous: ");
val2 = phosphorous();
Serial.print(val2);
delay(250);
Serial.print("Potassium: ");
val3 = potassium();
Serial.print(val3);
delay(3000);
byte nitrogen() {
// clear the receive buffer
mod.flushInput();
// switch RS-485 to transmit mode
digitalWrite(DE, HIGH);
digitalWrite(RE, HIGH);
delay(1);
// write out the message
for (uint8_t i = 0; i < sizeof(nitro); i++ ) mod.write( nitro[i] );
// wait for the transmission to complete
mod.flush();
// switching RS485 to receive mode
// delay to allow response bytes to be received!
//delay(100);
// read in the received bytes
for (byte i = 0; i < 7; i++) {
values[i] = mod.read();
Serial.print(values[i], HEX);
Serial.print(' ');
return values[4];
byte phosphorous() {
mod.flushInput();
delay(1);
for (uint8_t i = 0; i < sizeof(phos); i++ ) mod.write( phos[i] );
mod.flush();
//delay(100);
Serial.print(' ');
return values[4];
byte potassium() {
mod.flushInput();
delay(1);
for (uint8_t i = 0; i < sizeof(pota); i++ ) mod.write( pota[i] );
mod.flush();
//delay(100);
Serial.print(' ');
return values[4];
Please suggest what is the correct way to get the correct NPK values.
