nRF2401 with Arduino Pro Mini 5v16Hz
Hi everyone,
I tried nRF2401 with 2 arduino uno r3, and they worked well.
Now I'm trying to connect with arduino pro mini 5v-16hz (since I'm working on small portable stuff). Same connection but doesn't work.
The reason why I'm using a 5v arduino pro mini is because I'm also connecting a MPU 6050 GY521 gyroscope with this thing, and the handy GY521 can't work with voltage lower than 5v. The arduino pro mini has no 3.3v vcc so I add a resistor to the 5v vcc and the output turns out to be around 3.0-3.2, I checked the specs of nRF2401, and it seems to be OK. Also since I have only one FTDI cable, so i'm powering up one of the pro mini with a 9v battery. Does anyone catch any potential error? Thanks a lot!!!
I'm testing with simple code like below:
for sender:
#include <nRF24L01.h>
#include <RF24.h>
#include <RF24_config.h>
#include <SPI.h>
int msg[1];
RF24 radio(7,8);
const uint64_t pipe = 0xE8E8F0F0E1LL;
void setup(void){
radio.begin();
radio.openWritingPipe(pipe);}
void loop(void){
for (int x=0;x<255;x++){
msg[0] = x;
radio.write(msg, 1);
for receiver:
#include <RF24.h>
#include <SPI.h>
int msg[1];
RF24 radio(7, 8);
int red = 3;
int green = 5;
int redNeg = 4;
int greenNeg = 6;
int lastmsg = 1;
void setup(void) {
radio.begin();
radio.openReadingPipe(1, pipe);
radio.startListening();
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(redNeg, OUTPUT);
pinMode(greenNeg, OUTPUT);
digitalWrite(greenNeg, LOW);
digitalWrite(redNeg, LOW);
void loop(void) {
if (radio.available()) {
bool done = false;
while (!done) {
radio.read(msg, 2);
if (msg[0] != lastmsg + 1) {
digitalWrite(red, HIGH);
digitalWrite(green, LOW);
else {
digitalWrite(red, LOW);
digitalWrite(green, HIGH);
lastmsg = msg[0];
Serial.println(msg[0]);
else {
I also have this same problem ..
Always use code tags when posting code (see "How to use this forum").
That won't work at all.
The current draw of the NRF24L01 is very high when transmitting, and the voltage drop across a resistor will be so large that transmissions will always fail.
You MUST use a 3.3V regulator and also, most people find that is helpful to add a 10-100 uF capacitor across the GND and Vcc terminals of the NRF24L01, as close as possible to the module.
Another option is to remove the 5V regulator from the Pro Mini, and power both modules with 2X AA batteries throught the Vcc pins.
One possible thing come to mind now:
Is the input voltage for nRF causing the problem? Should I use a regulator or better circuit?
jremington:
Good catch!! Yes. I just realize similar things. Thanks so much!!!!!!
