Hello guys i have 3 nrf24lo1, i master and two slaves
master to one slave is working fine but when i introduce the 3rd slave the data is not been read by the master
here is the master code
#include "Arduino.h"
#include <SPI.h>
#include <RF24.h>
#include "DHT.h"
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#include <TinyGPS++.h>
#define SD_CS 22
#define DHTPIN 2
HardwareSerial uart(1);
TinyGPSPlus gps;
// This is just the way the RF24 library works:
// Hardware configuration: Set up nRF24L01 radio on SPI bus (pins 10, 11, 12, 13) plus pins 7 & 8
//RF24 radio(7, 8);
RF24 radio(5, 15);
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHTPIN, DHTTYPE);
byte addresses[][6] = {"1Node", "2Node", "3Node"};
boolean buttonState = 0;
float h, t,lati, longi;
String temperature, humidity, latitude, longitude;
struct package
float temperature ;
float humidity ;
String hello ;
typedef struct package Package;
Package data;
Package data1;
// SETUP SETUP SETUP SETUP SETUP SETUP SETUP SETUP SETUP
uart.begin(9600, SERIAL_8N1, 17, 16);
Serial.println("THIS IS THE TRANSMITTER CODE - YOU NEED THE OTHER ARDIUNO TO SEND BACK A RESPONSE");
// Initiate the radio object
radio.begin();
dht.begin();
// Set the transmit power to lowest available to prevent power supply related issues
radio.setPALevel(RF24_PA_MIN);
// Set the speed of the transmission to the quickest available
radio.setDataRate(RF24_2MBPS);
// Use a channel unlikely to be used by Wifi, Microwave ovens etc
radio.setChannel(124);
radio.enableDynamicPayloads();
// Open a writing and reading pipe on each radio, with opposite addresses
radio.openWritingPipe(addresses[1]);
radio.openReadingPipe(1, addresses[0]);
radio.openReadingPipe(2, addresses[0]);
// radio.openReadingPipe(1, addresses[1]);
void senddata() {
// Wait a few seconds between measurements.
delay(2000);
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
data.humidity = dht.readHumidity();
// Read temperature as Celsius (the default)
data.temperature = dht.readTemperature();
radio.write( &data, sizeof(data) );
gps_Info();
void loop(){
// Ensure we have stopped listening (even if we're not) or we won't be able to transmit
radio.stopListening();
senddata();
// Did we manage to SUCCESSFULLY transmit that (by getting an acknowledgement back from the other Arduino)?
// Even we didn't we'll continue with the sketch, you never know, the radio fairies may help us
if (!radio.write( &data, sizeof( data) )) {
Serial.println("No acknowledgement of transmission - receiving radio device connected?");
delay(5);
radio.startListening();
while (!radio.available());
radio.read(&buttonState, sizeof(buttonState));
if (buttonState == HIGH) {
Serial.print("HIGH");
else {
Serial.println("LOW");
//delay(10);
radio.read(&data1, sizeof(data1));
Serial.print(data1.humidity,2);
Serial.println(data1.temperature,2);
Here's the slave thats always connecting
#include <SPI.h>
#include <RF24.h>
#include <Wire.h>
#define button 6
RF24 radio(7, 8);
LiquidCrystal_I2C lcd(0x27,20,4);
byte addresses[][6] = {"1Node","2Node","3Node"};
struct package
float temperature ;
float humidity ;
Package data;
String hello = "Hello";
int red = 2;
int green = 3;
int blue = 4;
int mintemp1 = 23.00;
int maxtemp1 = 26.00;
int maxtemp2 = 30.00;
int minhum1 = 70;
int maxhum1 = 80;
int maxhum2 = 100;
lcd.init();
//lcd.begin(16, 2);
lcd.backlight();
Serial.println("THIS IS THE RECEIVER CODE - YOU NEED THE OTHER ARDUINO TO TRANSMIT");
radio.begin();
radio.openWritingPipe(addresses[0]);
// Start the radio listening for data
pinMode(red, OUTPUT);
pinMode(green, OUTPUT);
pinMode(blue, OUTPUT);
digitalWrite(red, HIGH);
digitalWrite(green, HIGH);
digitalWrite(blue, HIGH);
pinMode(button, INPUT);
// We are LISTENING on this device only (although we do transmit a response)
if ( radio.available()) {
// Go and read the data and put it into that variable
while (radio.available()) {
radio.read( &data, sizeof(data));
lcd.setCursor(0, 0);
lcd.print("Temp ");
lcd.setCursor(0, 1);
lcd.print(data.temperature,2);
lcd.print(" C");
lcd.setCursor(8, 0);
lcd.print("Hum ");
lcd.setCursor(8, 1);
lcd.print(data.humidity,2);
lcd.print(" %");
Serial.println("Data Received");
// lcd.clear();
// lcd.print("No radio available");
Serial.println("Data not Received");
delay(5);
led();
buttonState = digitalRead(button);
radio.write(&buttonState, sizeof(buttonState));
void led(){
// const int temp = data.temperature,2;
if (data.temperature,2 <= mintemp1)
//digitalWrite(red, LOW);
digitalWrite(green, LOW);
// delay(1000);
// digitalWrite(green, HIGH);
if (data.temperature,2 > mintemp1)
// delay(1000);
Serial.println(data.temperature,2);
void ButtonState(){
