RF24 One master Two slaves
Hello everybody,
I beg your help for my for my project !
I would like to make arduinos communicate wirelessly with nrf24l01+
The idea is to have one master which receives the sensors datas from two points.
Each emitting point would send values from 100 sensors
I searched for hours but nothing work !
Please can someone explain what's wrong ?
Thank you in advance,
PS : sorry if my english is... so so !
Master code:
//*************Branchement**************************************************************
//                                                  RF      Name      Uno       Mega
//    |------------------------------|---|---|                        Nano
//    |  |___           ________     | 8 | 7 |      8       IRA       N/A       N/A
//    |   ___|         (________)    |---|---|      7       MISO      12        50
//    |  |___                        | 6 | 5 |      6       MOSI      11        51
//    |   ___|     |                 |---|---|      5       CSK       13        52
//    |  |___      |                 | 4 | 3 |      4       CSN       7*        7*
//    |   ___|     |                 |---|---|      3       CE        8*        8*
//    |  |_________|                 | 2 ||1||      2       VCC       3,3       3,3
//    |------------------------------|---|---|      1       GND       GND       GND
//                                                  * modifiable par variable
#include "nRF24L01.h"
#include "RF24.h"
#include <SPI.h>
const uint64_t pipes[] = { 0xF0F0F0F0E1LL,
                           0xF0F0F0F0E2LL,
                           0xF0F0F0F0E3LL
                         };      // MOD  : add slaves if required & copy to slaves code !
#define ThisNodeID 0             // Fix  : ID of this MASTER
#define wait 6000                // Fix  : max wait duration in us
int requestToNode;               // AUTO : switch between slave
int nbSlaves;                    // AUTO : number of node (master excluded)
uint32_t data;                   // AUTO : node message
bool Astat = 0;                  // AUTO : action status (OK/Not OK)
unsigned long At = 0;            // AUTO : last action (R/W) time in us
long Dt = 0;                     // AUTO : elapsed time in us
RF24 radio(9, 10);
  nbSlaves = (sizeof(pipes) / 8) - 1; // save the table size
  radio.begin();
  radio.setDataRate(RF24_250KBPS);
  radio.setRetries(0, 0);
  Serial.println(F("Master Initialized"));
  requestToNode = nbSlaves + 1;  // Initialize
  // Node switch
  if (requestToNode > nbSlaves) {
    requestToNode = 1;
  // Declare pipes
  radio.stopListening();
  radio.openWritingPipe(pipes[requestToNode]);
  radio.openReadingPipe(requestToNode, pipes[requestToNode]);
  radio.printDetails();
  // Send request == lock other nodes
  At = micros();
  Dt = 0;
  Astat = 0;
  while ((Dt <= wait) && (Astat == 0)) {
    Astat = radio.write(&requestToNode, sizeof(requestToNode));
    Dt = micros() - At;
    if (Astat == 1) {
      Dt = micros() - At;
      Serial.print(F("Sent request to Slave Node "));
      Serial.print(requestToNode);
      Serial.print(F(" in "));
      Serial.print(Dt);
      Serial.println(F(" us"));
  if (Astat == 0) {
    Serial.print(F("Send to Slave Node "));
    Serial.print(F(" failed. Waited "));
    Serial.print(Dt);
    Serial.println(F(" us. Realeased for fresh data"));
  // Receive data from Slave
  radio.startListening();
  At = micros();
  Dt = 0;
  Astat = 0;
    Dt = micros() - At;
    if (radio.available()) {
      radio.read(&data, sizeof(data));
      Dt = micros() - At;
      Astat = 1;
      Serial.print(F("Received from Slave Node "));
      Serial.print(F(" : "));
      Serial.print(data / 10000);
      Serial.print(F(" "));
      Serial.print(data % 10000);
      Serial.print(F(", in "));
      Serial.print(Dt);
  if (Astat == 0) {
    Serial.print(F("Receive from Slave Node "));
    Serial.print(Dt);
  // Request next Slave node
  requestToNode = requestToNode + 1;
Slave code :
//                                                  RF      Name      Uno       Mega
#include "RF24.h"
#include <SPI.h>
                           0xF0F0F0F0E2LL,
                           0xF0F0F0F0E3LL
#define ThisNodeID 1             // MOD  : ID of this NODE
#define wait 8000                // Fix  : max wait duration in us
unsigned long Dt = 0;            // AUTO : elapsed time in us
uint32_t value = 2000000;        // AUTO : storage
RF24 radio(9, 10);
  radio.begin();
  radio.openWritingPipe(pipes[ThisNodeID]);
  radio.openReadingPipe(ThisNodeID, pipes[ThisNodeID]);
  Serial.println(F("Slave "));
  Serial.print(ThisNodeID);
  Serial.println(F(" Initialized"));
  // Message
  if (value > 2000000) {
    value = 1001234;
  else {
    value = value + 10000;
  // Waiting GO from Master
  At = micros();
  Dt = 0;
  Astat = 0;
    Dt = micros() - At;
      Dt = micros() - At;
      if (data == ThisNodeID) {
        Dt = micros() - At;
        Astat = 1;
        Serial.print(F("Go received after "));
        Serial.print(Dt);
  if (Astat == 0) {
    Serial.print(F("Go from Master Node missed. Waited "));
    Serial.print(Dt);
  // Remplacement valeur data
  data = value;
  // Send value
  if (Astat == 1) {
    At = micros();
    Dt = 0;
    Astat = 0;
      Astat = radio.write(&data, sizeof(data));
      Dt = micros() - At;
      if (Astat == 1) {
        Serial.print(F("Sent "));
        Serial.print(data);
        Serial.print(F(" to Master Node in "));
        Serial.print(Dt);
    if (Astat == 0) {
      Serial.print(F("Send to Master Node failed. Waited "));
      Serial.print(Dt);
Take a look at the code in this post i think it will give you a good starting point.
http://forum.arduino.cc/index.php?topic=411686.0
I got my nRF24s working with this Tutorial
I suggest you use the TMRh20 version of the RF24 library - it solves some problems from the ManiacBug version
The pair of programs in this link may be useful. The master program can easily be adapted to talk to several slaves.
...R
With that many sensors, you will have to divide your data into 32 byte packets.
As Robin2 suggests, get an example working then expand from there.
Great ! Many thanks for the reply.
I'll try with the links you've mentioned.
I'll keep you informed !
try here GitHub - 6leonardo/RF24_PROTO: A radio protocol for Arduino & RF24 radio
