Hello everyone.
I bought 2 NRF24L01 + PA + LNA and I'm trying to make them work, but I can't.
I have this model so I can plug my radios to Arduino 5v.
CE --> D9
CSN --> D10
SCK --> D13
MOSI --> D11
MISO --> D12
VCC --> 5v
GND --> GND
I made those connections with 1 radio with a Nano and 1 with and a Uno.
In my code, I used radio.isChipConnected and it seems that my connections are ok because it returns yes with the 2 arduinos.
BUT, when I copy a code from a website or a forum, I can't send or receive datas and I don't know why. I tried 5 codes, changed all my wires, used a 3,3v converter, inversed the radios, but nothing worked.
Here one of my code (from this topic)
for the transmitter :
// TRANSMITTER
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3,5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
send();
prevMillis = millis();
void send() {
bool rslt;
rslt = radio.write( &dataToSend, sizeof(dataToSend) );
// Always use sizeof() as it gives the size as the number of bytes.
// For example if dataToSend was an int sizeof() would correctly return 2
Serial.print("Data Sent ");
Serial.print(dataToSend);
if (rslt) {
Serial.println(" Acknowledge received");
updateMessage();
else {
Serial.println(" Tx failed");
void updateMessage() {
// so you can see that new data is being sent
txNum += 1;
if (txNum > '9') {
txNum = '0';
dataToSend[8] = txNum;
and for the receiver :
// RECEIVER
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
getData();
showData();
void getData() {
if ( radio.available() ) {
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
void showData() {
if (newData == true) {
Serial.print("Data received ");
Serial.println(dataReceived);
newData = false;
In the console, I get this from the transmitter :
SimpleTx Starting
Data Sent Message 0 Tx failed
And this from the receiver :
SimpleRx Starting
If you have any ideas, please help me because I have a deadline.
Thank you everyone
