Hi!
I was about to finalize my project, but then thunder strikes...
I'm hoping to finish today, since I need it soon. I have all day available just to fix this.
So, I have 4x NRF24L01, 3 of them are transmitters, one is receiver.
Program has been tested (test situation; one atMega328P(as transmitter) on a breadboard and one UNO(as receiver) which worked great, I simply do have one breadboard, so that's why.
Obviously I made the test program in a test environment until I was happy.
Then, I created 3 finalized transmitter boxes; which basically is an PIR, battery holder(2xAA 3v), atMega328P and a NRF..
Tested this with the UNO receiver, worked as well, no problems at all.
So then trouble started.
Now I was at the point where the receiver should come of the UNO to be a bare atMega328P
- Burned bootloader for 8Mhz internal clock (transmitters do the same) according to tutorial, and succesful. I do this quite a lot, so I know that's good.
- Uploaded the sketch for the receiver (8Mhz internal clock board)
- Then: it did not work!
I do see my 'boot-LED' blinking. But there seems to be no radio communication. And also in the serial monitor I can see my boot messages.
The fun thing is, I took an extra UNO from my storage, connected all the wiring back again (if you have the UNO and atMega328 on a breadboard next to each other, it's really easy to make a quick and correct wiring copy). Powered it up and uploaded the sketch and it worked.
So the transmitters work without crystal and capacitors, I did do a test with the atMega328P with crystal and capacitors, same results.
I checked all the wiring
Wiring:
SCK === PIN 13 (atMega 19)
MISO === PIN 12 (atMega 18)
MOSI === PIN 11 (atMega 17)
CE === PIN 10 (atMega 16)
CSN === PIN 9 (atMega 15)
PSU === 3V chip and NRF on the same supply
I did not post my code, since I think it's not relevant to my problem, if you would like to see the code I'll be happy to share it here.
