As instructed I followed This tutorial Simple nRF24L01+ 2.4GHz transceiver demo - Exhibition / Gallery - Arduino Forum made by a fellow user named Robin2. The pins are correct and the sample code
Tx - Transmitter
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3,5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
send();
prevMillis = millis();
void send() {
bool rslt;
rslt = radio.write( &dataToSend, sizeof(dataToSend) );
// Always use sizeof() as it gives the size as the number of bytes.
// For example if dataToSend was an int sizeof() would correctly return 2
Serial.print("Data Sent ");
Serial.print(dataToSend);
if (rslt) {
Serial.println(" Acknowledge received");
updateMessage();
else {
Serial.println(" Tx failed");
void updateMessage() {
// so you can see that new data is being sent
txNum += 1;
if (txNum > '9') {
txNum = '0';
dataToSend[8] = txNum;
Receiver
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
getData();
showData();
void getData() {
if ( radio.available() ) {
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
void showData() {
if (newData == true) {
Serial.print("Data received ");
Serial.println(dataReceived);
newData = false;
Its stuck at "SimpleRx Starting" So I followed Reply #29 which diagnose this sort of problem as it just tests the connection between the Arduino and its nRF24 without attempting to send or receive any data to / from another nRF24.
See Attachment Below.
Questions:
- ) What did you use to power Arduino
- For the Transmitter I used 9v and for the Receiver I used the laptop's usb port (Im thinking that the voltage in the usb port cannot power NRF24l01)
2.) There's a lot of topics that includes "NRF24l01 is not Working"
- Yeah I spent my time searching it and none of them works, although Im planning to buy 5V-3.3V VCC Adapter Board for NRF24L01 Wireless Module maybe that might fix it.
- ) What battery are you using?
- Ultra Alkaline
DiagnosticTest.txt (2.57 KB)
