Hello
Before doing this project:
There was already a made receiver and remote.
But i didnt not have receiver code and remote(transmitter) was trashed beyond saving.
So i made new program on receiver, with only difference to hardware i used arduino nano every instead of regular arduino nano.
I made a new remote, schematic bellow.
For remote i also used arduino nano every. I am quite pleased with arduino nano every as it boots blazingly fast.
On remote i use regular nRF24L01 and on receiver end it is used NRF24L01+ PA/LNA.
Yeah i know it makes more sense to use NRF24L01+ PA/LNA on transmitter but i am limited with space + it was done like this originally.
But i am having big problems with working distance which currently is 20m.
Googling it they suggest to:
- change speed to 250kbps
- transmitting power to high or max
- change channel (set to 120 now)
- and put a capacitator between GND and VCC of module
I was also thinking if there is some interferrence from some other device, but even if i try it else where i get same results.
I tried replacing nRF24L01 since i have multiple in case there was something wrong with them.
I did all of above mentioned without any better results.
I am looking at schematic and arduino nano every uses AP2112 which is regular LDO with 600mA for 3.3V so i dont see how that could present problems or is it that i could have problems because of drop-down switcher in nano every?
Ill take it home during weekend to hook it up to osciloscope to check voltage stability or to make receiver and transmitter with regular arduinos .
Below schematic of remote and transmitter, reciver code.
But i am guessing if there was any code problems communication wouldnt work at all.
Any ideas/help is greatly appreciated.
#include "Arduino.h"
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#include<avr/wdt.h> //watchdog
RF24 radio(9, 10); // CE, CSN
const byte address[6] = "00001";
const long power_off_interval = 5000;
const long transmit_interval = 80;
const long button_error_interval = 20000;
unsigned long currentMillis = 0;
unsigned long previousMillisPOff = 0;
unsigned long previousMillisTransmit = 0;
unsigned long previousMillisBlinking = 0;
unsigned long previousMillisBErrordetect = 0;
const int button1 = 2;
const int button2 = 3;
const int button3 = 4;
const int powerPin = 5;
const int ledPin = 6;
const int batteryVolTreshold = 181; // 3.55V
int batteryVol = 0;
boolean button1State = HIGH;
boolean button2State = HIGH;
boolean button3State = HIGH;
int state = 0; // 1 = ok voltage, 2 = low voltage, 3 = error
bool error = false;
bool ledOn = false; // keep track of the led state
bool ledBlinking = false;
long ledBlinking_interval = 500;
Receiver:
wdt_reset(); // Reset the watchdog
wdt_enable(WDT_PERIOD_512CLK_gc); // Enable the watchdog with a timeout of 0.512 second
pinMode(powerPin, OUTPUT);
pinMode(ledPin, OUTPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT_PULLUP);
radio.begin();
radio.openWritingPipe(address);
radio.setRetries(15, 10); //every time it transmits 10 times with a delay in between of 15 * 250uS = 4000uS - 4ms
radio.setChannel(120);
radio.setPALevel(RF24_PA_HIGH);
radio.setDataRate(RF24_250KBPS);
radio.powerUp();
radio.stopListening(); //This sets the module as transmitter
digitalWrite(powerPin, HIGH);
digitalWrite(ledPin, LOW);
previousMillisPOff = millis();
currentMillis = millis();
button1State = digitalRead(button1);
button2State = digitalRead(button2);
button3State = digitalRead(button3);
// AUTOMATIC POWER OFF
if ((currentMillis - previousMillisPOff <= power_off_interval) && (button1State == LOW || button2State == LOW || button3State == LOW))
// if button is not pressed for longer then interval it turns off the arduino
if (currentMillis - previousMillisPOff >= power_off_interval) {
digitalWrite(powerPin, LOW);
// VOLTAGE INDICATOR
// fully charged battery is 4.1v
// nominal voltage is 3.7v
// 3.55v is where i start signaling low battery voltage, which corresponds to 181 value
batteryVol = analogRead(A0);
if (error == false){
if(batteryVol > batteryVolTreshold){
state = 1;
}else{
state = 2;
// LED
if (state == 1){
}else if(state == 2){
ledBlinking = true;
}else{
ledBlinking = true;
ledBlinking_interval = 125;
if (ledBlinking == false){
digitalWrite(ledPin, HIGH);
}else{
if ((currentMillis - previousMillisBlinking) >= ledBlinking_interval){
ledOn = !ledOn;
if (ledOn){
digitalWrite(ledPin, HIGH); // turn led on
digitalWrite(ledPin, LOW); // turn led off
previousMillisBlinking = millis();
// ERROR DETECTION
// if 2 buttons pressed
if(((button1State == LOW)&&(button2State == LOW)) || ((button1State == LOW)&&(button3State == LOW))|| ((button2State == LOW)&&(button3State == LOW))){
error = true;
if ((currentMillis - previousMillisBErrordetect) >= button_error_interval) {
error = true;
if (error == true){
state = 3;
// BUTTONS
if ((((currentMillis - previousMillisTransmit) >= transmit_interval)) && (error == LOW)) {
if ((button1State == LOW)&&(button2State == HIGH)&&(button3State == HIGH)) { // if button 1 pressed
char text[] = "1119";
radio.write(&text, sizeof(text));
} else if ((button1State == HIGH)&&(button2State == LOW)&&(button3State == HIGH)) { // if button 2 pressed
char text[] = "2229";
} else if ((button1State == HIGH)&&(button2State == HIGH)&&(button3State == LOW)) { // if button 3 pressed
char text[] = "3339";
} else { // no button pressed we reset error detection for button
previousMillisBErrordetect = millis();
previousMillisTransmit = millis();
Transmitter:
#include <SPI.h>
#include <RF24.h>
int batteryVol = 0;
bool error = false;
radio.begin();
radio.powerUp();
state = 1;
}else{
state = 2;
// LED
if (state == 1){
ledBlinking = true;
}else{
ledBlinking = true;
}else{
ledOn = !ledOn;
if (ledOn){
// ERROR DETECTION
error = true;
error = true;
if (error == true){
state = 3;
// BUTTONS
