Hi Guys,
I am having trouble changing the payload length. If I just use static payload length then everything works fine. Below is the code for static length payload:
void NRF24L01_INIT(void)
int PAYLOAD_LEN = 20;
SPI_Write_Byte(EN_AA, 0x01); //Enable auto-acknowledgment for data pipe 0
SPI_Write_Byte(EN_RXADDR, 0x01); //Enable data pipe 0
SPI_Write_Byte(SETUP_AW, 0x03); //Set address width to 5 bytes
SPI_Write_Byte(RF_CH, 0x69); //Set channel frequency to 2.505GHz
SPI_Write_Byte(RF_SETUP, 0x26); //Set data rate to 250kbps and 0dB gain
nRF_Set_Addr_RX(N1_address, NRF_ADDR_LEN); //Set the 5-bytes receiver address as 0x11 0x12 0x13 0x14 0x15
nRF_Set_Addr_TX(BS_address, NRF_ADDR_LEN); //Set the 5-bytes transmitter address as 0x11 0x12 0x13 0x14 0x15
SPI_Write_Byte(RX_PW_P0, PAYLOAD_LEN); //Set the payload width as 20-bytes
void SPI_Write_Byte(unsigned char reg, unsigned char data)
_delay_us(10);
PORTB &= ~_BV(CSN); //CSN low
_delay_us(10);
SPI_Tranceiver(W_REGISTER + reg);
_delay_us(10);
SPI_Tranceiver(data);
_delay_us(10);
PORTB |= _BV(CSN); //CSN high
Now I wanted to have dynamic payload option. so I changed the code like this:
//toggle_features();
SPI_Write_Byte(FEATURE, 0x1D);
SPI_Write_Byte(EN_DPL, 0x02 );
// Enable dynamic payload on pipe 0
SPI_Write_Byte(DYNPD, 0x1C);
SPI_Write_Byte(DPL_P0, 0x00);
Now anywhere on the code I can just call
int PAYLOAD_LEN = 10
and change the payload length.
But it is not working. Datasheet says:
In order to enable DPL the EN_DPL bit in the FEATURE register must be set. In RX mode the DYNPD register
has to be set. A PTX that transmits to a PRX with DPL enabled must have the DPL_P0 bit in DYNPD
set.
I set everything but not transmitting. Do anybody has an idea?
