Nrf24l01 works on Uno ftdi and not working on other Uno boards
The voltages seem OK.
That only leaves the SPI signals causing the problem but I can't see how they would prevent an upload.
However, again you have clones so who knows how they have SPI connected.
I cant know definitely which board is correct. Because all transmissions between all boards are printed as failed.
Though!
I assume in my posts that there is a correct one among them. That one where at least the process of printing out the information on Serial is well done. So the first Screen has one table with good data in it and then goes list of statuses of transmition attempts.
And the second Screen shot is identical for other two boards.
Concretely, the printing out of data begins from incontinous repetead table of initial configuration of Nrf. As you see it is printed 1000 times again and again.
Abd to show you that this the same peace of code (of setup function) I have added "Nnnnn" line to it.
If you are printing a single "N" in setup and multiple consecutive "N" characters appear in your printout, then the conclusion must be that the Arduino is crashing repeatedly.
 * Copyright (C) 2011 J. Coliz <maniacbug@ymail.com>
 * This program is free software; you can redistribute it and/or
 * modify it under the terms of the GNU General Public License
 * version 2 as published by the Free Software Foundation.
 * Example using Dynamic Payloads
 * This is an example of how to use payloads of a varying (dynamic) size.
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
RF24 radio(9, 10);  // Set up nRF24L01 radio on SPI bus plus pins 7 & 8
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t addresses[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
/************************* Role management ****************************/
// Set up role.  This sketch uses the same software for all the nodes in this
// system.  Doing so greatly simplifies testing.
// The role_pin is a digital input pin used to set the role of this radio.
// Connect the role_pin to GND to be the 'pong' receiver
// Leave the role_pin open to be the 'ping' transmitter
const short role_pin = 5;  // use pin 5
typedef enum { role_ping_out = 1,
               role_pong_back } role_e;                                     // The various roles supported by this sketch
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back" };  // The debug-friendly names of those roles
role_e role;        // The role of the current running sketch
// variables used for changing the payload size dynamically (used when role == role_ping_out)
const int min_payload_size = 4;
const int max_payload_size = 32;
const int payload_size_increment = 1;
int send_payload_size = min_payload_size;
char receive_payload[max_payload_size + 1];  // +1 to allow room for a terminating NULL char
void setup(void) {
  pinMode(role_pin, INPUT);  // set up the role pin
  digitalWrite(role_pin, HIGH);
  delay(20);  // Just to get a solid reading on the role pin
  // read the role_pin, establish our role
  if (digitalRead(role_pin)) {
    role = role_ping_out;
    role = role_pong_back;
  printf_begin();  // needed for printDetails()
  Serial.println("NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN");
  // Print preamble
  Serial.println(F("RF24/examples/pingpair_dyn/"));
  Serial.print(F("ROLE: "));
  Serial.println(role_friendly_name[role]);
  // Setup and configure rf radio
  radio.begin();
  radio.enableDynamicPayloads();  // Enable dynamic payloads
  radio.setRetries(5, 15);        // delay between retries = 5 * 250 + 250 = 1500 microseconds, number of retries = 15
  // Open a writing and reading pipe on each radio, with opposite addresses
  if (role == role_ping_out) {
    radio.openWritingPipe(addresses[0]);
    radio.openReadingPipe(1, addresses[1]);
    radio.openWritingPipe(addresses[1]);
    radio.openReadingPipe(1, addresses[0]);
  radio.startListening();  // Start listening
  radio.printDetails();    // Dump the configuration of the rf unit for debugging
  /****************** Ping Out Role ***************************/
    // The payload will always be the same, what will change is how much of it we send.
    static char send_payload[] = "ABCDEFGHIJKLMNOPQRSTUVWXYZ789012";
    radio.stopListening();  // First, stop listening so we can talk.
    // Send the payload
    Serial.print(F("Now sending length "));
    Serial.println(send_payload_size);
    radio.write(send_payload, send_payload_size);  // This will block until complete
    radio.startListening();  // Now, continue listening
    unsigned long started_waiting_at = millis();  // Start a timer for measuring timeout
    bool timeout = false;
    while (!radio.available() && !timeout)  // Wait until we get a response or timeout is reached
      if (millis() - started_waiting_at > 500)  // Only wait for 500 milliseconds
        timeout = true;
    // Describe the results
    if (timeout) {
      Serial.println(F("Failed, response timed out."));
      // Grab the response and print it
      uint8_t len = radio.getDynamicPayloadSize();  // get payload's length
      // If an illegal payload size was detected, all RX payloads will be flushed
      if (!len)
        return;
      radio.read(receive_payload, len);
      // Use payload as a C-string (for easy printing)
      receive_payload[len] = 0;  // put a NULL terminating zero at the end
      // Spew it
      Serial.print(F("Got response size="));
      Serial.print(len);
      Serial.print(F(" value="));
      Serial.println(receive_payload);
    send_payload_size += payload_size_increment;  // Update size for next time.
    if (send_payload_size > max_payload_size)     // if payload length is larger than the radio can handle
      send_payload_size = min_payload_size;       // reset the payload length
    delay(1000);  // Try again 1s later
  /****************** Pong Back Role ***************************/
  // Receive each packet, send it back, and dump it out
  if (role == role_pong_back) {
    while (radio.available())  // if there is data ready
      uint8_t len = radio.getDynamicPayloadSize();  // Fetch the the payload size
      if (!len)
        continue;
      // Spew it
      Serial.print(len);
      // Send a reply that the packet was received
      // You will have better luck delivering your message if
      // you wait for the other node to start listening first
      delay(20);
      radio.write(receive_payload, len);
      Serial.println(F("Sent response."));
      radio.startListening();  // Now, resume listening so we catch the next packets.
}  // loop
// vim:cin:ai:sts=2 sw=2 ft=cpp
Can the problem be because the author of pingpair is maniacbug and the author of library I use is another one. I use library which stored in the folder called Rf-master. And the example "Pingpairdyn.ino" is from its subfolder "/examples/old_backups"
But I heard that people advice to use nrf library by TmRh20
Software can't be the cause of the not being able to upload problem.
Yes, it is true.
Tell please what means listening to Sip? What concrete pin because there are 4? Or you mean Vcc?
I'm only concerned with the fact you can't upload unless you disconnect the nRF Vcc from the board. If it was drawing too much current I would expect a drop in the 5V but you said it was at 5.15V. So what else could be causing the problems? The SPI pins (all 4), or the CE and CSN connections? I'm just guessing at this point.
It's difficult to diagnose a problem like this through chatting on the forum. We could go back and forth for days with people asking "do you try this?"
Yes it is so. But what should I check on spi? As i understand it communicates very complexly. On the level of packages of data. So in my level of understanding it seems to me that I can check some concrete signals on ce or csn. For example if ce is 1 nrf not idle than .. and somthinv like this.
Maybe i can check Powet level?
Really in the screen 1 - power level high and on the boards where not working nrf - power level is low.
And as I by myself saw - i tried some sketch which said that the nrf is idle.
And on the board with the first screen - i think it is connected with Power Level.
Here is some man measures the pa and lna. But i couldnt find how. Is there a pin or something programmtic - maybe read some registers?
Because using a library RF for this will not help - it will measure with delay. Maybe on plotter for port (for other board) somehow can i output pa and lna.
I'm just looking at your pictures in post #10. It appears that you are not connecting the nrf24L01's adapter board directly to the Uno. You are instead connecting it to what appears to be an APC220/Bluetooth sensor shield, as already pointed out.
Further, the orange wire, at the point where it enters the 5v header on that shield, looks burned (although that may simply be a problem with the picture). If there has been an overload on that shield it could have damaged the 5v pin on the Uno.
Do you get the same power related problems (continuous crashing/inability to upload) when you remove the sensor shield and use the Uno directly with the nrf24L01 adapter?
I started using this shield first day ago.
Before this i didnot use any shield and tried to make nrf work for two weeks.
It was last attempt a day ago - i thought maybe it will help and it is lazy to reconmect nrf to usual board.
All pins and cables work i make so - i take antenna, take cables out of one board and insert them in the other. And also tried other cables but nothing.
I cannot understand.
