I want to do some ADC with a board that uses the nRF52840 (specifically the promicro version) and I started with the timing code for it but am seeing some odd behaviour when I check the timing with micros(). Whether this is an artefact of how micros() works or something else is what I would like to find out.
So I am firing an interrupt every 4ms and incrementing a flag in the ISR, and in the main loop I'm polling as fast as possible to check when the flag gets to 250 and when it does, I check the time with micros() and save the time in a variable before resetting the counters. Next time the main loop detects 250 ISR counts I print the time that has passed.
So firstly as the ISR and loop() are asynchronous I would expect a bit of jitter in the time that passed, I expect it to be about 1 second but since the loop executes about every 24uS I would expect the time that passed from loop to loop to vary by around this amount (but it does not).
And then also I am seeing every now and then a large delay of around 1ms (so instead of reporting 1000000uS the loop is reporting 1000976uS or so).
Maybe this is because micros() does something odd but this is expected behaviour and I should not trust it, but maybe the whole processor stops for a millisecond now and then in which case my ADC will be thrown off and I'll need to make huge code contortions to manage it as far as I can see.
Can anyone throw any light on this? I should say that I've already used (what I think are) higher level libraries like the software timer one but had similar problems with them all so ended up doing it as low level as I could find info on for maximum control but still no joy. Hence starting to think its something to do with micros() and this is simply not able to actually measure microseconds but is estimating them or rounding them or something.
In general, the micros values doesn't look realistic. Note that the loopcount exhibits noticeable jitter, while the micros doesn't. The fact that micros outputs exact as 1 million with an accuracy of 1 µs is also abnormal.
The µs values looks like to be updated once per ms and were calculated by simply multiplying millis by 1000. This also can explains why it changed by 977 at a single jump.
Yes I agree. The loopcount looks exactly what I would expect, since this loop is free running. But the exactly (to the uS) elapsedtime is weird - impossible really since the loop is not synchronised to the interrupt and the loop takes 24uS. Your hypothesis of the millis being multiplied by 1000 makes sense but what about the 977 (this exact value varies by 2 or 3 iirc but its fairly stable). I don't see that fitting into the multiply by 1000 scenario but maybe I'm missing something.
It does seem like its micros() thats to fault here and much less likely to be the interrupt. Maybe since this chip is new to Arduino they bodged the implementation of micros() for now and intend to come back to it or something in the future.
Probably what I should do is somehow count clock pulses. Not sure exactly how to do this other than using a counter again and there is a call that retrieves the current count. Only problem is I'm already using one counter and I'm not sure how many there are available (the system takes one or more IIRC but I think there are 4, will need to check).
If there are spares I should probably rewrite this without micros() and using the counter and see if the problem persists.
@sonofcy I know that looks weird, when you're familiar with the syntax of the atmega Arduino stuff much of this does to me anyway. There aren't many references to timer code on the web for this chip but after quite a lot of research this does seem to be the right way to set these timers up (although I am very much still rookie with this).
On ArduinoCore-avr millis() counts the overflow of a timer. This timer runs at 1.024ms. Since millis() cannot return fractions it runs too slow. To correct this, the fraction is collected and causes millis() to jump by 2 every now and than (approx every 42ms).
Maybe the NRF core does something similar and you see the correction of millis().
LGTM
You have an interrupt vector table. This is a list of function pointers. TIMER4_IRQn is the index where you can find the pointer to TIMER4_IRQHandler.
So I removed the micros() call and replaced it with a second 32 bit / 1MHz timer which just counts up for an hour or so (1MHz at 32 bits is about 1 hour 10 mins). Its possible to call a function to return the current count so this can act as a 1MHz clock.
I cant be totally certain that this is not also 'pausing' and so faking the results (since its triggered by the main clock if there was a problem that low down, it could affect both this timer and the everything else etc). But it seems really unlikely that this is the case as its and internal function of the chip implemented in hardware AFAIK and unless some code actually calls it to pause nothing is going to make it do so.
This gives very different results, exactly the results that would be expected.
Note that I slipped some ADC calls in there but it was the same before adding them. They just show that the ADC does not massively affect the timings. They are just summed and printed to stop them being optimised out but I will be stuffing them into an array eventually.
Theres a little jitter to and fro on the ElapsedTime, but it averages out to zero which is expected. Occasionally up to about +-28uS which is about right for a loop function thats running at about 38000 Hz. Again jitter in the loopcount as expected.
To me this all looks completely fine now, but could I ask if anyone else sees any issues now?
Clearly micros() is not of any use on the nRF52840 though anyway.
@Rintin thats interesting thanks for the detail. Something I did notice was that there didn't seem to be any exact perodicity to the extra 1ms delay, but I didn't set up to carefully measure that. I just printed the time in uS on single lines, with newlines when the time was greater than 500uS late and observed that the newlines happened at very different and quite random logging line lengths. Still, it seemed to be worst at the start of execution and become more regular later. I would be interested to look at the source for this stuff but not sure where to look. Maybe the mechanism would be obvious. I saw the same effect in the nRF52Timerinterrupt library with a frequency of about 250 Hz interrupt rate. When I changed the rate by a couple of Hz up or down the effect saw a very large change (IE at maybe 248 Hz the 1000970 uS delay was happening at a 1:4 ratio instead of a 1:50 ratio at 252Hz). I guess this does show some kind of 'beat frequency' effect similar to what you explained.
Anyway reading the source code would probably be better than speculating, but I am glad my other test with the counter seems to be fine, I can go ahead and continue with the application I was working on. Just got to remember to not use milis() on this platform.
Just to close this up - I didn't realise but this board runs freeRTOS (I think all arduino cores run freeRTOS - the pcook one I am using certainly does but all the others I looked at did too).
So freeRTOS uses a tick frequency of 1kHz and in delay.h in the source for the pcook BSP I found this:
static inline uint32_t micros( void )
// Use DWT cycle count if it is enabled, otherwise use rtos tick
return dwt_enabled() ? (DWT->CYCCNT / 64) : tick2us(xTaskGetTickCount());
DWT is "Debug, Watchdog, and Trace" but I have not played with it. Its a direct system clock counter by all accounts. Perhaps reliable but I'm not sure what happens to it when you put the cpu to sleep as the 64MHz clock gets sleeped too. Anyway tick2us must be a x1000 multiplier since it takes ticks at 1kHz and outputs microseconds. But clearly the resolution is going to be 1000us. Meaning it can't be used as a microsecond timer.
So this seems to confirm, if you want anything better than 1millisecond resolution, use a counter one way or the other - figure out the DWT thing or use an appropriate counter for your sleep level. I am using the 32kHz clock now so that will be all I can do but its still better than 1kHz.
