Hello everyone,
I have built a robot for my senior project to perform color tracking in real time. The robot uses arduino uno, a pixy 2 camera, 2 DC motors and a L298N motor controller. The robot works fine, the only problem is that the robot is still trying to move after reaching the object. So I have decided to use an ultrasonic sensor in order to stop the motors before reaching the object. Due to limitation of time I need some help with the commands and where to add them in my existing code which you can find here. Thank you
#include <PIDLoop.h> //###############################################
#include <Pixy2.h> //IMPORTING LIBRARIES
Pixy2 pixy; //###############################################
// ENA IN1 IN2 IN3 IN4 ENB
int myPins[6] = {5, 6, 7, 8, 9, 10};
float deadZone = 0.15; //dead zone tha defines where the object will not move at all equals to 15%
int baseSpeed = 250; // base speed that the robot will run
int cont = 0;
int signature, x, y, width, height;
float cx, cy, area;
Serial.print("Starting...\n");
pixy.init();
for (int i = 0; i < 6; i++) {
pinMode(myPins*, OUTPUT); //declaring all pins as output using a for loop*
void loop() { - float turn = pixyCheck(); //checking the value of the turn. how much deviation we have from the center using the pixy check function *
- if (turn > -deadZone && turn < deadZone) { //applying deadzone*
- turn = 0;*
- if (turn < 0) {*
- moveRobot(170, -80); //deciding how much to move the robot*
- else if (turn > 0) { //looking if the turn is positive or negative and moving, otherwise keep going forward*
- moveRobot(-80, 170);*
- else {*
- moveRobot(70, 70); //takes the value of the left speed and the right speed*
- delay(1);*
float pixyCheck() { - static int i = 0;*
- int j;*
- uint16_t blocks;*
- char buf[32];*
- // grab blocks!*
- blocks = pixy.ccc.getBlocks();*
- // If there are detect blocks, print them!*
- if (blocks)*
- signature = pixy.ccc.blocks[0].m_signature;*
- height = pixy.ccc.blocks[0].m_height; //height of the object*
- width = pixy.ccc.blocks[0].m_width; //width of the object*
- x = pixy.ccc.blocks[0].m_x;//x value of the object*
- y = pixy.ccc.blocks[0].m_y;//y value of the object*
- cx = (x + (width / 2)); //center x position*
- cy = (y + (height / 2)); //center y position*
- cx = mapfloat(cx, 0, 320, -1, 1); // aplying normalization. If value is from 0-320 change from -1 to 1. This helps in the computation*
- cy = mapfloat(cy, 0, 200, 1, -1);*
_ area = width * height;_ - //Serial.print("sig: ");*
- //Serial.print(signature);*
- //Serial.print(" x:");*
- //Serial.print(x);*
- //Serial.print(" y:");*
- //Serial.print(y);*
- //Serial.print(" width: ");*
- //Serial.print(width);*
- //Serial.print(" height: ");*
- //Serial.print(height);*
- //Serial.print(" cx: ");*
- //Serial.print(cx);*
- //Serial.print(" cy: ");*
- //Serial.println(cy);*
- else {*
- cont += 1;*
- if (cont == 100) {*
- cont = 0;*
- cx = 0;*
- return cx; //sending back the x location to tell our robot to turn in a particular direction whether is positive or negative*
float mapfloat(long x, long in_min, long in_max, long out_min, long out_max)
return (float)(x - in_min) * (out_max - out_min) / (float)(in_max - in_min) + out_min;
void moveRobot(int leftSpeed, int rightSpeed)
{ - if (leftSpeed >= 0) {*
- digitalWrite(myPins[1], 0);*
- digitalWrite(myPins[2], 1);*
- else {*
- digitalWrite(myPins[1], 1);*
- digitalWrite(myPins[2], 0);*
- if (rightSpeed >= 0) {*
- digitalWrite(myPins[3], 0);*
- digitalWrite(myPins[4], 1);*
- else {*
- digitalWrite(myPins[3], 1);*
- digitalWrite(myPins[4], 0);*
- analogWrite(myPins[0], abs(leftSpeed));*
- analogWrite(myPins[5], abs(rightSpeed));*
