I'm currently making an object following robot using the Pixy CMUcam5. My issue is the robot is only turning the right motor and left motor isn't doing anything.
The Pixy is connected to an Arduino Uno, and the motors are connected to an Adafruit Motor shield on ports M1 and M2.
One other thing I've noticed is that the Pixy and motors dont seem to work unless the pixy is connected to the computer via USB. I'm not sure if this means it's lacking power.
The power which I'm trying to use is supplied by a 9v to the Arduino Uno and 4AA batteries to the Motor sheild.
The code I've used comes from Pixy Pet Code Design | Pixy Pet Robot - Color vision follower | Adafruit Learning System which I've adjusted a bit to work with the Motor shield.
Any help is appreciated
#include <SPI.h>
#include <Pixy.h>
#include <Wire.h>
#include <AFMotor.h>
AF_DCMotor leftMotor(1); //Left Motor on Motorshield
AF_DCMotor rightMotor(2); //Right Motor on Motorshield
#define X_CENTER 160L //Taken from the Pixy CMUcam5 code
#define Y_CENTER 100L
#define RCS_MIN_POS 0L
#define RCS_MAX_POS 1000L
#define RCS_CENTER_POS ((RCS_MAX_POS-RCS_MIN_POS)/2)
// Servo Loop Class
// A Proportional/Derivative feedback
// loop for pan/tilt servo tracking of
// blocks.
// Some code taken from Bill Earl and Pixy CMUcam5 to compile ther servoloop
class ServoLoop
public:
ServoLoop(int32_t proportionalGain, int32_t derivativeGain);
void update(int32_t error);
int32_t m_pos;
int32_t m_prevError;
int32_t m_proportionalGain;
int32_t m_derivativeGain;
// ServoLoop Constructor
ServoLoop::ServoLoop(int32_t proportionalGain, int32_t derivativeGain)
m_pos = RCS_CENTER_POS;
m_proportionalGain = proportionalGain;
m_derivativeGain = derivativeGain;
m_prevError = 0x80000000L;
// ServoLoop Update
// Calculates new output based on the measured
// error and the current state.
void ServoLoop::update(int32_t error)
long int velocity;
char buf[32];
if (m_prevError!=0x80000000)
velocity = (error*m_proportionalGain + (error - m_prevError)*m_derivativeGain)>>10;
m_pos += velocity;
if (m_pos>RCS_MAX_POS)
m_pos = RCS_MAX_POS;
else if (m_pos<RCS_MIN_POS)
m_pos = RCS_MIN_POS;
m_prevError = error;
// End Servo Loop Class
Pixy pixy; // The camera used
ServoLoop panLoop(200, 200); // Servo loop for pan
ServoLoop tiltLoop(150, 200); // Servo loop for tilt
// Setup
Serial.print("Starting...\n");
pixy.init();
leftMotor.setSpeed(0);
rightMotor.setSpeed(0);
leftMotor.run(RELEASE);
rightMotor.run(RELEASE);
uint32_t lastBlockTime = 0;
// Main loop
uint16_t blocks;
blocks = pixy.getBlocks();
// If we have blocks in sight, track and follow them
if (blocks)
int trackedBlock = TrackBlock(blocks);
FollowBlock(trackedBlock);
lastBlockTime = millis();
else if (millis() - lastBlockTime > 100)
leftMotor.setSpeed(255);
leftMotor.run(FORWARD);
rightMotor.setSpeed(255);
rightMotor.run(FORWARD);
ScanForBlocks();
int oldX, oldY, oldSignature;
// Track blocks via the Pixy pan/tilt mech
// (based in part on Pixy CMUcam5 pantilt example)
int TrackBlock(int blockCount)
int trackedBlock = 0;
long maxSize = 0;
Serial.print("blocks =");
Serial.println(blockCount);
for (int i = 0; i < blockCount; i++)
if ((oldSignature == 0) || (pixy.blocks[i].signature == oldSignature))
long newSize = pixy.blocks[i].height * pixy.blocks[i].width;
if (newSize > maxSize)
trackedBlock = i;
maxSize = newSize;
int32_t panError = X_CENTER - pixy.blocks[trackedBlock].x;
int32_t tiltError = pixy.blocks[trackedBlock].y - Y_CENTER;
panLoop.update(panError);
tiltLoop.update(tiltError);
pixy.setServos(panLoop.m_pos, tiltLoop.m_pos);
oldX = pixy.blocks[trackedBlock].x;
oldY = pixy.blocks[trackedBlock].y;
oldSignature = pixy.blocks[trackedBlock].signature;
return trackedBlock;
// Follow blocks via the robot drive
// This code makes the robot base turn
// and move to follow the pan/tilt tracking
// of the head.
int32_t size = 400;
void FollowBlock(int trackedBlock)
int32_t followError = RCS_CENTER_POS - panLoop.m_pos; // How far off-center are we looking now?
// Size is the area of the object.
// We keep a running average of the last 8.
size += pixy.blocks[trackedBlock].width * pixy.blocks[trackedBlock].height;
size -= size >> 3;
// Forward speed decreases as we approach the object (size is larger)
int forwardSpeed = constrain(400 - (size/256), -100, 400);
// Steering differential is proportional to the error times the forward speed
int32_t differential = (followError + (followError * forwardSpeed))>>8;
// Adjust the left and right speeds by the steering differential.
int leftSpeed = constrain(forwardSpeed + differential, -400, 400);
int rightSpeed = constrain(forwardSpeed - differential, -400, 400);
// And set the motor speeds
leftMotor.setSpeed(100);
rightMotor.setSpeed(100);
// Random search for blocks
// This code pans back and forth at random
// until a block is detected
int scanIncrement = (RCS_MAX_POS - RCS_MIN_POS) / 150;
uint32_t lastMove = 0;
void ScanForBlocks()
if (millis() - lastMove > 20)
lastMove = millis();
panLoop.m_pos += scanIncrement;
if ((panLoop.m_pos >= RCS_MAX_POS)||(panLoop.m_pos <= RCS_MIN_POS))
tiltLoop.m_pos = random(RCS_MAX_POS * 0.6, RCS_MAX_POS);
scanIncrement = -scanIncrement;
if (scanIncrement < 0)
delay(random(250, 500));
