Obstacle avoiding robot doesn't detect black dots
firstly, i m beginner. Because of that i didn't understand exactly where the problem is, but i think its somewhere in my code.The project I want to do is as follows:
A robot will be created, which will systematically navigate a white square area (1.5m x 1.5m) with 3 cm long black dots on it. While the robot is walking around (by escaping walls), if it detects a black dot on the ground, it will wait without moving for 1 second, make a sound from the buzzer for 2 seconds and continue searching for the dots (3 seconds in total). I thought about the movement algorithm of this robot as follows:
Start moving forward, if you see a black dot, wait for 1 second, ring the buzzer for 2 seconds and continue on your way. If the distance between you and the wall is less than 5 cm,go backward a little bit, turn right (there is no problem at that part) but this code does not do what I want. The part I complain about in this code is that The infrared sensor does not detecting black dots and does not perform the function we want when detect black dots. its just keep going like nothing there I'd be happy if anyone helps.
the things i used:
2 dc motor
1 l298 motor driver
1 ultrasonic sensor (hc-SR04)
3 infared sensor and sensors driver (F233-01, generally used in line-following robots)
1 buzzer
and arduino uno
the code:
const int SagMotorileri = 9;
const int SagMotorgeri = 10;
const int MotorEnableSag = 6;
const int SolMotorileri = 2;
const int SolMotorgeri = 3;
const int MotorEnableSol = 5;
const int infraredSensorPin1 = 4;
const int infraredSensorPin2 = 12;
const int infraredSensorPin3 = 13;
const int triggerPin = 7;
const int echoPin = 8;
const int buzzerPin = 11;
int DuvarMesafe = 0;
  pinMode(SagMotorileri, OUTPUT);
  pinMode(SagMotorgeri, OUTPUT);
  pinMode(MotorEnableSag, OUTPUT);
  pinMode(SolMotorileri, OUTPUT);
  pinMode(SolMotorgeri, OUTPUT);
  pinMode(MotorEnableSol, OUTPUT);
  pinMode(infraredSensorPin1, INPUT);
  pinMode(infraredSensorPin2, INPUT);
  pinMode(infraredSensorPin3, INPUT);
  pinMode(triggerPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(buzzerPin, OUTPUT);
  DuvarMesafe = MesafeOlc();
  if (IRAlgila()) {
    buzz(); // Siyah nokta algılandığında sadece buzzer çalacak
    ileriGit();
  if(DuvarMesafe < 10){
    SagaDon();
bool IRAlgila() {
  return digitalRead(infraredSensorPin1) == LOW ||
         digitalRead(infraredSensorPin2) == LOW ||
         digitalRead(infraredSensorPin3) == LOW;
void ileriGit() {
  digitalWrite(SagMotorileri, HIGH);
  digitalWrite(SagMotorgeri, LOW);
  analogWrite(MotorEnableSag, 130);
  digitalWrite(SolMotorileri, HIGH);
  digitalWrite(SolMotorgeri, LOW);
  analogWrite(MotorEnableSol, 115);
  while (DuvarMesafe >= 10 ) {
    delay(50);
void SagaDon() {
   digitalWrite(SagMotorileri, LOW);
  digitalWrite(SagMotorgeri, HIGH);
  digitalWrite(SolMotorileri, LOW);
  digitalWrite(SolMotorgeri, HIGH);
  MotorlariDurdur();
  delay(200);
  delay(800);
  MotorlariDurdur();
  delay(200);
void MotorlariDurdur() {
void buzz() {
  digitalWrite(buzzerPin, HIGH);
  delay(2000);
  digitalWrite(buzzerPin, LOW);
int MesafeOlc() {
  digitalWrite(triggerPin, LOW);
  delayMicroseconds(2);
  digitalWrite(triggerPin, HIGH);
  delayMicroseconds(10);
  return pulseIn(echoPin, HIGH) * 0.0343 / 2;
I suggest to write a very simple program that just reads the sensor and reports the result on the serial monitor. Test the sensor function to see if it is working correctly.
When it is working correctly, place to robot on the intended surface, move it around by hand, and tune the program to detect black dots.
as ı said i m begginer i dont know how to do that can you give me an example
Your posted program has code in it to read the sensors. Make a new program, removing from the original all code that is not required to read the sensor, and test it.
That way you will start to learn something about programming Arduinos, which is a valuable skill!
does this work? if it is, my sensor is giving me just random numbers
const int infraredPin = A0; // Analog pin to which the sensor is connected
  Serial.begin(9600); // Initialize serial communication
  int sensorValue = analogRead(infraredPin); // Read the sensor value
  Serial.print("Infrared Sensor Value: ");
  Serial.println(sensorValue); // Print the sensor value to the serial monitor
  delay(1000); // Delay for 1 second before the next reading
Did you forget to study the posted code?
It defines these pins as as sensor pins, and reads them using digitalRead().
It would be a good idea to check if those pins are actually connected to sensors.
i also tried this but nothing changed. it still cant understand black dots
  if (IRAlgila()) {
    buzz()
bool IRAlgila() {
void buzz() {
  delay(100);
  delay(2000);
What does it see instead? Use Serial.print() to see the sensor readings. For example
Serial.print("Sensor1 = ");
Serial.println(digitalRead(infraredSensorPin1));
You will need to add Serial.begin() to setup function, with an appropriate serial Baud rate.
Basics first!
it read every where white! it just keep going
How do you know that?
What does Serial.print() report, for each of the three individual sensors?
In your first piece of code you use digitalRead() to read your IR sensor. In your second piece of code you use analogRead(). Why is that?
If you can't tell the answer: you really need to first learn the basics, and get some understanding on how an Arduino reads inputs, and what it means. Start maybe by asking whoever gave you the robot and code for a more detailed explanation.
The project you have sounds like a great learning project, it has a lot in it, far more than you appear to understand. You have to understand basics like pin numbers, analog vs. digital inputs, the meaning of HIGH and LOW, etc. Otherwise you're just poking around in the dark randomly and all that happens is either you get frustrated because nothing seems to work, or you destroy the board by making a mistake in your wiring and then you get frustrated about that. Neither is useful.
Maybe start out clean on a simpler, less complex version of your project first, and then add on to it so you don't have a huge burden all at once.
Hello @clkerdmmmm - Do you have problems or questions about your robot and the black dot sensor (or code, DC motors, L298N, HC-SR04, buzzer or Uno)?
