obstacle avoiding robot
heeeelp i can't fix the arduino code for "my obstacle avoiding robot" i use just ine servomotor for the distance detecteur HC-SR04 and for the wheels i use motors but without the motor shields so plzzzzz i neeeeed your heeelp :cry: :cry: :cry:
Got a little bit confused...Do you want to ask for suggestions on motor driver shield? Maybe you can try L298N. Check this: http://www.sunfounder.com/index.php?c=showcs&id=96&model=L298N%20Stepper%20Motor%20Drive&pname=Arduino&name=Module&pid=21.
Mohamedamine:
Help us to help you by providing your code so far, a schematic of the circuit, and an explanation of what's wrong with the way it works.
SallyG_SF:
Got a little bit confused...Do you want to ask for suggestions on motor driver shield? Maybe you can try L298N. Check this: http://www.SunFounder.com
There's nothing at all in the OP's post that could confuse you into thinking s/he is looking for a driver. Perhaps your obvious sunfounder affiliation (_SF in your handle) confuses you into seeing a sunfounder solution in every problem.
If s/he is looking for a motor driver, a 298 is a crap solution in the year 2015. Pololu has a good range of smaller more efficient modern solutions here.
