Of Millis, Fade and Stay ON or Off
Hello Everyone. I am new here and new to Arduino programming. I am experimenting with millis() to better understand it. I found a sketch at The Bald Engineer to fade an LED up and then down. I think I understand this pretty much. I also read over the Tute here.
I thought I might try altering the code so the led will fade in, then stay on a few seconds, then turn off. However, now I get nothing. Could someone please take a look at the this code and tell me where I am going wrong.
#define UP 0
#define DOWN 1
const int minPWM = 0;
const int maxPWM = 255;
byte fadeDirection = UP;
int fadeValue = 0;
byte fadeIncrement = 5;
unsigned long previousFadeMillis;
unsigned long previousMillis;
int fadeInterval = 50;
int onInterval = 3000;
  analogWrite(pwmLED, fadeValue);
void doTheFade(unsigned long thisMillis) {
     if (thisMillis - previousFadeMillis >= fadeInterval) {
     if (fadeDirection == UP) {
         fadeValue = fadeValue + fadeIncrement;
     if (fadeValue >= maxPWM) {
          fadeValue = maxPWM;
      if (pwmLED, maxPWM)  {
 }      analogWrite(pwmLED, HIGH);
      if (thisMillis - previousMillis >= onInterval) {
 }     analogWrite(pwmLED, LOW);
    previousMillis = thisMillis;
    previousFadeMillis = thisMillis;
                                                          // get the current time, for this time around loop
  unsigned long currentMillis = millis();                    // all millis() timer checks will use this time stamp
  doTheFade(currentMillis);
Use CTRL T ( or CMD T ) to format your code.
What is this ?
if (pwmLED, maxPWM)
Thanks
That was a mistake. I changed it to; if (pwmLED == maxPWM) However, I am still getting nothing on the LED.
Well guys, still not working. Here is the corrected code. Still does nothing.
// Example Fading LED with analogWrite and millis()
// See baldengineer.com/fading-led-analogwrite-millis-example.html for more information
// Created by James Lewis
#define UP 0
#define DOWN 1
int pwmLED = 5;
int fadeValue = 0;
         fadeValue = maxPWM;
    if (pwmLED == maxPWM)  {
Hint
int pwmLED = 5;
Thank you. A little help sometimes is all is needed
Well, I did all the corrections suggestions, still see nothing but a dimly lit LED haunting me. Thanks for all your help. It back t the tutorial boards for me.
Show us your latest incarnation.
larryd:
Here it is
#define UP 0
#define DOWN 1
int pwmLED = 3;
int fadeValue = 0;
unsigned long thisMillis2;
         fadeValue = maxPWM;
       if (fadeValue == maxPWM) {
    if (pwmLED == HIGH)  {
  previousMillis = thisMillis2;
You have:
int pwmLED = 3;
You then you have:
if (pwmLED == HIGH)
You essentially have:
if (pwmLED == HIGH) or with numbers if (3 == HIGH)
Stop, and read the above over and over until you understand the problem :wink: .
That's not very bright.
(Pun intended)
Hey guys.
My original idea was to fade in a red LED, then hold it high for a for a while. After it has been high for a bit , then fade in a yellow to make orange. Then fade out the red to make yellow only for a time. Then continue with green and blue to simulate a rainbow. To me, it's quite daunting, after learning how to fade without delay.
Thing is, I am getting really frustrated now so I think the best thing is to leave it and go on to some other projects for a while.
Thanks everyone.
