I will be mounting four N-ch MOSFETs onto individual heatsinks on a solderable panel laid out like a breadboard. The MOSFETs will be handling 12 Volts.
I understand that the drain of each MOSFETs is connnecetd to the back plane of the TO-220 package.
The heatsinks came with the insulation pads, and insulating collars for the screws so that the drain of the MOSFET can be electrically insulated from the heat sink.
However, the heatsinks have a pin that fits into the breadboard directly opposite the drain pin of the mounted MOSFET. This means that no matter how well insulated the back of the MOSFET is from the heatsink, it will be electrically connected via the 'breadboard' anyway.
So, I am considering mounting the MOSFETs without the insulating pad, and using some thermal paste to improve the heat transfer. I will also mount the heatsinks so that there is a gap between the heatsink and the other rows of the 'breadboard'. I have some Dow Corning 340 silicone heat sink compound. I believe that the electrical insulation pad reduces the thermal transfer, so better thermal transfer will be achieved without it.
Since these are N-channel MOSFETs, I understand that doing this will mean that the heatsinks can be expected to have be the same as the ground when the the MOSFETs are passing current. Since the heatsinks will not be touching anything else, I can't see any electrical problems with this, but that is why I am asking here....
Does this make sense?
I am also aware that anodising on the heatsinks may provide some insulation, but I am ignoring that.
What dangers are there, if any, of bonding the drains to individual heatsinks?
One of the four will be simple on/off
The other three will use varying levels of dimming.
I am driving the MOSFETs using TC4427 MOSFET drivers.
I have been able to test one 5m length LED strip and the MOSFET did not get warm, but I am adding the heatsinks for the bigger loads I expect when it is in place. When I have it in place I will see how hot the heatsinks get when under the full 5A load and decide if I need more heatsink. I dont know of a way to create a 5A test load.
At least you're using a MOSFET driver, this will insure fast switching which in turn means that you will loose as little power as possible when switching! This is important for high-current and high frequency PWM switching where you could otherwise loose a great deal of power in your MOSFETs!
Arduino PWM frequency is normally 490 Hz, which is quite low in terms of PWM. So with a driver maybe you could even do without heat sinks on any of your MOSFETS. But of course if you want to feel a little safer, a small heat sink should be sufficient.
If you were to drive the MOSFET directly from the PWM pin and at a much higher frequency you could run into problems with switching power loss.
I initially tried to use them without MOSFET drivers but I could only get 7V out of the MOSFET instead of 12V, so I read what I could about MOSFET drivers and ordered the TC4427 drivers.
Here is how I am connecting things up. (showing one of the four, a second TC4427 also drives a pair of MOSFETs:
The typical failure mode of a MosFet is fully ON. However in your case the failure result would simply be your LED's on all the time. In addition, most 12V sources have current limiting and will survive a shorted output. I will admit some sources do better at handling a short than others.
thanks, my power source is one of those 12V 30A units fro China, so I have no idea what it would do if there was a short... I have the LED strips running about in the ceiling of the basement, so I may leave the 7A fuses in line.
Fuses protect wires. A MOSFET will blow faster than any fast-blow fuse. It is impossible to protect valuable components like that.
But if something happens, like the cat knocks it off your workbench and a piece of metal contacts the wrong thing then you really don't want to have 30A heating up the wires. That can start a fire and even a small fire on the workbench is much more costly than a MOSFET.
Couldn't find the exact MOSFET with "LE" at the end, but it looks like the FQP30N06 has a RDS(on) of about 0.03 ohms typical at anything below 10A.
This means that you will dissipate R*I² = 0.03 * 5 * 5 = 0.75W in your MOSFET when fully on.
The thermal resistance to ambient, without a heat sink is 62.5 °C/W, which means you will heat up the MOSFET about 47°C (116°F) above ambient when fully on. If it sits in a well ventilated area that would actually be okay, but still it should feel quite warm or hot to the touch!
Even a small simple u-shaped heat sink would probably halve that temperature increase.
Black anodized heatsinks are best, BTW - they radiate heat as well as passing it to the air by convection.
Shiny bare metal doesn't radiate much at all at lowish temperatures (which is why radiators are painted).
thanks for the calculations... I got it all wired up last night and today I will test them under load.
I am using small black heatsinks... and they are in the open air below a train layout. The power supply that drives it all is mounted on the wall nearby and it has a variable speed fan that also moves air about so I think it will be fine...
