Hi. I have a problem with my OLED display for my Arduino code. It shows dots only after I upload the code. I have used lora to transmit the gps data from one another.
Here is the code:
Trasnmitter:
// Transmitter
#include <SoftwareSerial.h>
#include <AltSoftSerial.h>
#include <TinyGPS++.h>
#include <SPI.h> // include libraries
#include <LoRa.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
static const int RXPin = 8, TXPin = 9;
static const uint32_t GPSBaud = 9600;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(RXPin, TXPin); // for gps
String outgoing; // outgoing message
byte msgCount = 0; // count of outgoing messages
byte destination = 0xFF;
byte localAddress = 0xBB;
long lastSendTime = 0; // last send time
int interval = 2000; // interval between sends
// For Oled display
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
String Mymessage = "";
// Size of the geo fence (in meters)
const float maxDistance = 30;
float initialLatitude = 34.014875;
float initialLongitude = 72.163585;
float latitude, longitude;
char buff[10];
String mylong = ""; // for storing the longittude value
String mylati = ""; // for storing the latitude value
int msgstatus;
int Sensor1;
int relay = 3;
float distance;
* setup() function
//Serial.println("Arduino serial initialize");
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextColor(WHITE);
pinMode(relay, OUTPUT);
//Serial.println("NEO6M serial initialize");
ss.begin(GPSBaud);
if (!LoRa.begin(433E6)) {
Serial.println("LoRa init failed. Check your connections.");
while (true); // if failed, do nothing
Serial.println("LoRa init succeeded.");
* loop() function
while (ss.available() > 0)
if ( gps.encode(ss.read() ) )
displayInfo();
latitude = gps.location.lat(), 6 ;
longitude = gps.location.lng(), 6 ;
mylati = dtostrf(latitude, 3, 6, buff);
mylong = dtostrf(longitude, 3, 6, buff);
distance = getDistance(latitude, longitude, initialLatitude, initialLongitude);
if (millis() - lastSendTime > interval) {
//displayInfo();
// Serial.print("Latitude= "); Serial.println(latitude, 6);
//Serial.print("Lngitude= "); Serial.println(longitude, 6);
if(distance > maxDistance) {
msgstatus =1;
if(distance < maxDistance) {
msgstatus =0;
// Serial.print("Distance: ");
//Serial.println(distance);
Mymessage = Mymessage + mylati +"," + mylong+","+msgstatus + "," +distance ;
sendMessage(Mymessage);
//Serial.println(Mymessage);
delay(50);
Mymessage = "";
//Serial.println("Sending " + message);
lastSendTime = millis(); // timestamp the message
// parse for a packet, and call onReceive with the result:
onReceive(LoRa.parsePacket());
// Calculate distance between two points
float getDistance(float flat1, float flon1, float flat2, float flon2) {
// Variables
float dist_calc=0;
float dist_calc2=0;
float diflat=0;
float diflon=0;
// Calculations
diflat = radians(flat2-flat1);
flat1 = radians(flat1);
flat2 = radians(flat2);
diflon = radians((flon2)-(flon1));
dist_calc = (sin(diflat/2.0)*sin(diflat/2.0));
dist_calc2 = cos(flat1);
dist_calc2*=cos(flat2);
dist_calc2*=sin(diflon/2.0);
dist_calc +=dist_calc2;
dist_calc=(2*atan2(sqrt(dist_calc),sqrt(1.0-dist_calc)));
dist_calc*=6371000.0; //Converting to meters
return dist_calc;
void sendMessage(String outgoing) {
LoRa.beginPacket(); // start packet
LoRa.write(destination); // add destination address
LoRa.write(localAddress); // add sender address
LoRa.write(msgCount); // add message ID
LoRa.write(outgoing.length()); // add payload length
LoRa.print(outgoing); // add payload
LoRa.endPacket(); // finish packet and send it
msgCount++; // increment message ID
void onReceive(int packetSize) {
if (packetSize == 0) return; // if there's no packet, return
// read packet header bytes:
int recipient = LoRa.read(); // recipient address
byte sender = LoRa.read(); // sender address
byte incomingMsgId = LoRa.read(); // incoming msg ID
byte incomingLength = LoRa.read(); // incoming msg length
String incoming = "";
while (LoRa.available()) {
incoming += (char)LoRa.read();
if (incomingLength != incoming.length()) { // check length for error
//Serial.println("error: message length does not match length");
return; // skip rest of function
// if the recipient isn't this device or broadcast,
if (recipient != localAddress && recipient != 0xFF) {
// Serial.println("This message is not for me.");
// if message is for this device, or broadcast, print details:
//Serial.println("Received from: 0x" + String(sender, HEX));
//Serial.println("Sent to: 0x" + String(recipient, HEX));
//Serial.println("Message ID: " + String(incomingMsgId));
// Serial.println("Message length: " + String(incomingLength));
// Serial.println("Message: " + incoming);
// Serial.println("RSSI: " + String(LoRa.packetRssi()));
// Serial.println("Snr: " + String(LoRa.packetSnr()));
// Serial.println();
String q = getValue(incoming, ',', 0); // Latitude
Serial.println(q);
Sensor1 = q.toInt(); // latitude
if ( Sensor1 == 1 )
digitalWrite(relay, HIGH);
if ( Sensor1 == 0 )
digitalWrite(relay, LOW);
void displayInfo()
Serial.print(F("Location: "));
if (gps.location.isValid())
Serial.print(gps.location.lat(), 6);
Serial.print(F(","));
Serial.print(gps.location.lng(), 6);
Serial.print(" ");
Serial.print(F("Speed:"));
Serial.print(gps.speed.kmph());
Serial.print(F("INVALID"));
Serial.print(F(" Date/Time: "));
if (gps.date.isValid())
Serial.print(gps.date.month());
Serial.print(F("/"));
Serial.print(gps.date.day());
Serial.print(gps.date.year());
Serial.print(F(" "));
if (gps.time.isValid())
if (gps.time.hour() < 10) Serial.print(F("0"));
Serial.print(gps.time.hour());
Serial.print(F(":"));
if (gps.time.minute() < 10) Serial.print(F("0"));
Serial.print(gps.time.minute());
if (gps.time.second() < 10) Serial.print(F("0"));
Serial.print(gps.time.second());
Serial.print(F("."));
if (gps.time.centisecond() < 10) Serial.print(F("0"));
Serial.print(gps.time.centisecond());
String getValue(String data, char separator, int index)
int found = 0;
int strIndex[] = { 0, -1 };
int maxIndex = data.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++) {
if (data.charAt(i) == separator || i == maxIndex) {
found++;
strIndex[0] = strIndex[1] + 1;
strIndex[1] = (i == maxIndex) ? i+1 : i;
return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
Receiver:
//Receiver
#include <LoRa.h>
int Buzzer=5;
int button=4;
int buttonState;
int Distance;
boolean Bflag = false;
String SenderNode = "";
byte localAddress = 0xFF; // address of this device
byte destination = 0xBB; // destination to send to
String statusmessage = "";
int Sensor1 = 0; // Latitude
int Sensor2 = 0; // Longitude
int Sensor3 = 0; // Status
String DayNight = "";
Serial.begin(9600); // initialize serial
pinMode(Buzzer,OUTPUT);
pinMode(button,INPUT_PULLUP);
if (!LoRa.begin(433E6)) { // initialize ratio at 915 MHz
// Serial.println("LoRa init succeeded.");
if ( (digitalRead(button) == LOW) && ( Bflag == false ) )
buttonState = 1;
Bflag = true;
if ( (digitalRead(button) == HIGH )&& (Bflag == true))
buttonState = 0;
Bflag = false;
statusmessage = statusmessage + buttonState + "," ;
sendMessage(statusmessage);
delay(50);
statusmessage = "";
if( sender == 0XBB )
SenderNode = "Node1:";
// // if the recipient isn't this device or broadcast,
// if (recipient != Node1 && recipient != MasterNode) {
// // Serial.println("This message is not for me.");
// return; // skip rest of function
//Serial.println("RSSI: " + String(LoRa.packetRssi()));
//Serial.println("received value");
String r = getValue(incoming, ',', 1); // Longitude
String s = getValue(incoming, ',', 2); // Status
String t = getValue(incoming, ',', 3); // Status
Sensor1 = q.toDouble(); // latitude
Sensor2 = r.toDouble(); // longitude
Sensor3 = s.toInt(); // status
Distance = t.toInt();
//Serial.println(q);
//Serial.println(r);
//Serial.println(s);
if (Sensor3==1)
digitalWrite(Buzzer,HIGH);
digitalWrite(Buzzer,LOW);
incoming = "";
//clear display
display.setTextSize(2);
display.setCursor(0, 10);
display.print(q); // Latitude
display.setCursor(0, 30);
display.print(r); // Longitude
display.setCursor(0, 50);
display.print("S:" + s +" D:"+Distance); // Status and distance
display.display();
int found = 0;
found++;
Here is the code. Please help meee
Hello sattttt12
Run some tutorials for the hardware selected.
If you are happy with the results of the tutorials you can merge these to your project.
Start at the begining.
Write a program that just prints a test message on the display, does that work OK ?
