Encore besoin de vous ! lol
Ce sketch, ci dessous, fonctionne très bien
Mais lorsque je passe de :
tft.setRotation(0); --> à tft.setRotation(1);
tout tourne bien mais les coordonnées de boutons changent (cad il faut que je touche ailleurs dans l'écran (plus sur les boutons on et off) pour changer la couleur du carré
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
MCUFRIEND_kbv tft;
#include <TouchScreen.h>
#define MINPRESSURE 200
#define MAXPRESSURE 1000
const int XP = 6, XM = A2, YP = A1, YM = 7; //ID=0x9341
const int TS_LEFT = 907, TS_RT = 136, TS_TOP = 942, TS_BOT = 139;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button on_btn, off_btn;
int pixel_x, pixel_y; //Touch_getXY() updates global vars
bool Touch_getXY(void)
TSPoint p = ts.getPoint();
pinMode(YP, OUTPUT); //restore shared pins
pinMode(XM, OUTPUT);
digitalWrite(YP, HIGH); //because TFT control pins
digitalWrite(XM, HIGH);
bool pressed = (p.z > MINPRESSURE && p.z < MAXPRESSURE);
if (pressed) {
pixel_x = map(p.x, TS_LEFT, TS_RT, 0, tft.width()); //.kbv makes sense to me
pixel_y = map(p.y, TS_TOP, TS_BOT, 0, tft.height());
return pressed;
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
void setup(void)
uint16_t ID = tft.readID();
if (ID == 0xD3D3) ID = 0x9486; // write-only shield
tft.begin(ID);
tft.setRotation(0); //PORTRAIT
tft.fillScreen(BLACK);
on_btn.initButton(&tft, 60, 200, 100, 40, WHITE, CYAN, BLACK, "ON", 2);
off_btn.initButton(&tft, 180, 200, 100, 40, WHITE, CYAN, BLACK, "OFF", 2);
on_btn.drawButton(false);
off_btn.drawButton(false);
tft.fillRect(40, 80, 160, 80, RED);
void loop(void)
bool down = Touch_getXY();
on_btn.press(down && on_btn.contains(pixel_x, pixel_y));
off_btn.press(down && off_btn.contains(pixel_x, pixel_y));
if (on_btn.justReleased())
on_btn.drawButton();
if (off_btn.justReleased())
off_btn.drawButton();
if (on_btn.justPressed()) {
on_btn.drawButton(true);
tft.fillRect(40, 80, 160, 80, GREEN);
if (off_btn.justPressed()) {
off_btn.drawButton(true);
