OneWire doesn't find sensors after updating to ESP32 platform version 2.0.17
Continuing the discussion from OneWire Library + ESP32:
Some version of this problem seems to have returned. There is no problem compiling, but I can't detect sensors with OneWire 2.3.8 and the 2.0.17 board core.
I have been using the 2.3.8 version from the library manager for some time and the OneWire part of my code (to use up to 8 temperature sensors) has always been reliable. Today I upgraded to Arduino ESP32 Board 2.0.17 and everything broke. I switched to the DS18x20_Temperature example and it found no addresses. I tested with Boards 2.0.10, 20.0.12, 2.0.13, and all were good. I went back to 2.0.17 and the problems returned.
I also tried the latest OneWire from GitHub in case there was another change, but it still failed.
I don't know whether to call this a OneWire bug or a board core bug, but I'll have to stay at 2.0.13 unless there is a fix.
Interesting. I have a different combination of board and OneWire version that works: esp8266 Core:3.1.2, OneWire 2.3.0 works
even though it complains at compile time:
128 | #warning "OneWire. Fallback mode. Using API calls for pinMode,digitalRead and digitalWrite. Operation of this library is not guaranteed on this architecture."
BUT, if I use any version of OneWire newer than 2.3.0 (e.g. 2.3.4 or the latest 2.3.8), the compile complaints go away but it finds 0 devices at runtime. That is:
OneWire oneWire(3);
DallasTemperature dallasTempSensors(&oneWire);
dallasTempSensors.begin();
dallasTempSensors.requestTemperatures();
return dallasTempSensors.getDeviceCount();
returns 0!
Not sure what the intersection of your issue is with mine, but they sure seem related. And ideas out there?
Since that post I have seen recommendations to use OneWireNg which has some explicit provisions of Espressif devices. I haven't tried it myself, but I intend to if the incompatibility persists much longer.
Hello @VeloSteve, just seen the whole thread. There have been multiple releases of the Arduino ESP32 core late last year; 2.0.18-arduino.5 is the latest and it has a number of fixes over 2.0.17. Can you confirm the issue persists with the current core?
Also, to double check, I assume you are familiar with pin numbering on the Nano ESP32 and are using "By GPIO number" and pin labels in your sketch?
@jtburgess I think your issue may be unrelated - the Arduino Nano ESP32 board (the topic for this forum... :wink:) uses an ESP32-S3, not an ESP8266.
But definitely check out OneWireNg if that helps :slight_smile:
Thank you for prompting me to check compatibility with the latest releases. I believe that there were other cores offered at one time, but these are the newest 3 I see in the IDE today. The most recent one works with the most recent OneWire, so pending testing the problem is solved for now.
OneWire Core Compiles? Messages
2.3.8 2.0.13 Yes
2.3.8 2.0.18.20240930.arduino3 No xtensa-esp32s3-elf-g++: error: CreateProcess: No such file or directory
2.3.8 2.0.18-arduino.5 Yes warning: extra tokens at end of #undef directive (and more)
