Only the first few LED's.. sometimes
Been away from Arduino/ESPP/MQTT for awhile and definitely missed it.
Trying to work on some lights for under a table and I think i’ve missed something crucial.
I’ve got a 5M strip of 5V RGB WS2812B here
https://www.aliexpress.com/item/Hello-Fish-5m-WS2812B-Pixels-LED-Strip-IP67-Waterproof-30-Pixels-m-Dream-Color-LED-Tape/32491428092.html?spm=2114.13010608.0.0.LEXdf5
This 5V, 8A Power supply
I’ve tried with both a Arduino Uno and an ESP8266. With the ESP8266 just the first 5 lights come on and seem random.
I’ve tested the power out of the supply at 5.5V
Pin 6 was connect to the data pin of the strip
the 5V to DC IN
and the grnd of the PS to the GND of the strip (not to the arduino)
But Nothing at all. I was thinking it was related to the data pin as an OUTPUT but that hope was crushed. No idea what i’m doing wrong.
#include <FastLED.h>
#define NUM_LEDS 60
#define DATA_PIN 6
CRGB leds[NUM_LEDS];
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
 leds[0] = CRGB::Red;
        FastLED.show();
        delay(30);
Show your wiring.
A common GND to the Arduino is needed.
Thank you Larry for the reply.
This morning I connected the common ground, similar to this diagram.
I get nothing on the first 8 LED’s, then a few random colors on LED 9-14 then nothing on the rest of the strip.
As in this picture
I’ve tested the voltage at the end of the LED strip and it shows 5.4V so it would appear something is wrong with the data or my code.
I’m running “FastLED version 3.001.003”
See:
Keep leads short.
Arduino to strip less than one foot.
The lights work with your Uno??
I just had an LED strip working in one place (msp430) and misbehaving in the other (ATTiny85). I had never burned my bootloader onto my smaller chip and so the clock wasn't running at the speed I expected -- causing bad light behaviour.
Reduce your strip LED number to like, 5, and see if only 5 things light up, too.
I just tested the same strip with a T-1000S controller and doesn't lit up. I tested another same model strip with the T-1000S and it lights up right away.
So, I think maybe the two (???) strips I tested had failed.
I'm going to test again tonight on a smaller strip and see if I can get anything at all.
I hope I didn't damage them during my previous tests...
To Andy's question - Not sure, I haven't seen anything yet. I have tried with a ESP8266 and an Uno. Nada on both.
Ok, now i’m really at a loss.
I picked up one of the test good strips (on the hardware controller) and plugged it into my Arduino Uno. Worked perfectly first try.
Then I copy the code, set the software to use the ESP 8266 and move the Digital Pin and Ground over. All i saw was the first 12-15 lights start flashing different colors, not the blue chase light I was testing before.
Basically I move two pins from one board to another and I go from working config to none.
Really at a loss for what to test
Here is the code
// Verion 1 T.S  Setup
//Inclusions
// Definitions
#define NUM_LEDS 300
#define LED_TYPE WS2812B
#define DATA_PIN D3
#define FASTLED_ESP8266_RAW_PIN_ORDER
#define FASTLED_ESP8266_NODEMCU_PIN_ORDER
#define FASTLED_ESP8266_D1_PIN_ORDER
  // pinMode(D3,OUTPUT);
  // Initial Array
void cycle() {    //This is a single led on/off at a time creating a single movement
        for(int dot = 0; dot < NUM_LEDS; dot++) {
            leds[dot] = CRGB::Blue;
            FastLED.show();
            // clear this led for the next time around the loop
            leds[dot] = CRGB::Black;
            delay(30);
}  // End cycle
 cycle();
// End of Loop
I've been reading around and no idea if thise is down the right path but
My WS2812B are only 3 wires. Many others that have used the ESP8266 have used a 4-wire with CLK. SOmething about bit banging and SPI. Frankly I don't really understand it.
Is there anything I can do to leverage these ESP8266 that I have. I really want to use these as I can connect to Wifi and use MQTT to control the lights.
Yep AndyD, the lights worked with the Uno (5V) but not the ESP8266 (3.3V)
There are a couple of things I'm going to do. For others that may stumble on this thread.
1 -- Add the capacitor per
2 -- Add a 74AHCT125 to level shift the 3.3V to 5V.
Ultimately, I'd prefer to use my ESP8266 board as it has the wifi that I want as opposed to my Uno which I need another shield.
I have a strip of 60 ws2812 leds (3 pin) working with esp8266 with no problems.
It seems the issue is related to the power supplied to the strip is 5V and the data pin phase is 3.3V so I need to add a 74AHCT125D or similar.
Will give this a try and see how we go.
I didn't have to use any level conversion. Let us know if that make it work.
PaulRB:
By chance are you using a Li-Ion battery at 3.7V to power your LED's and then using the ESP8266 to send 3.3V on Data Pin?
From what I've read, powering the strips with 5V and using a 3.3V on Data won't work.
Unless I'm doing something wrong.
How is your setup PaulRB?
Its all powered from a 5V wall-wart. Not enough current to light all 60 leds white at once, but my 60 leds are wrapped into a circle to make a clock and only a few are ever lit at the same time.
Interesting. Most of the people I see are required to use something to provide 5V on the Data pin since the esp8266 only supplies 3.3V.
I've never had luck with those LED running at 5v and the data at 3.3v.
Confirmed this morning after adding the 3.3V > 5V level-shifter that my sketch now works
In case anyone else has a similar issue, if you are powering your LED's via 5V, the data pin must receive at 5V as well and since the ESP8266 only outputs 3.3V you'll need to upshift.
I'm using a 74AHCT125 SMD (with super tiny contacts) so waiting to swap that out with a conversion board but as far as this morning tests, all good.
Thank you for the previous replys.
Glad you got it working. Thanks for reporting back, to help others. You are right, there is a lot of discussion around the net on this subject and it seems that sometimes it works without level shifters and sometimes it doesn't. As I said, I have never needed to use them, so far...
eeze:
From what I’ve read, powering the strips with 5V and using a 3.3V on Data won’t work.
It works that way.
