Opamp need 0- 10v analog out from pwm
Hi guys
Please give me some advice on the attached opamp schematic im trying to use a 0-3.3v pwm signal to control a spindle which needs 0-10v analog voltage, ive connected on breadboard but im only getting high or low volts nothing in between?
Thanks
From your diagram, you have a high pass filter on the output, it should be a low pass filter.
This link may help.
Tom... :grinning: :+1: :coffee: :australia:
@Undermentioned
What is the PWM frequency?
Your resistor values for the feedback are low. I'd go up a factor of 10.
How did you choose the values of 4k7 & 150nF for the filter?
What is the PWM coming from (exactly which "arduino"?)
What load does the "spindle" put on the output ? - you may need to buffer it.
This explains what I did to get a smooth analog value - using a high frequency PWM and a simple RC filter
See if this helps:
Handbook of operational amplifier applications
or this:
Why not do the low pass filtering on the MCU output before the Op Amp? Think I would use a 10 or 12 bit DAC with 5V reference, then amplify to 10V.
It is much easier and more accurate to use a 10V DAC than PWM and some op amp circuitry.
+1, I wasn't sure there were 10V+ models easily available to the hobbyist.
Depends where you live.
Back in the '70s and '80s when most of my work was with analog, I had pretty wide knowledge of devices from Burr-Brown, AD, National Semiconductor, etc., But that's all faded away. :disappointed_relieved:
+1
The output voltage of this circuit depends on the load you hang on the output.
If you filter first, and then amplify, you don't have that problem.
Leo..
See post #2 .
Tom..... :grinning: :+1: :coffee: :australia:
