I want to drive a FET or BJT with the logic output of an IC.
I see I can get the IC in open drain, or push pull.
If I use a pull-up with the open drain, is there some benefit of that over the push pull choice, or vice versa?
Push-pull means that the device will drive the pin high or low. Open drain means that the device can only drive the pin low, and you need an external pullup. For driving an external transistor, you probably want push-pull.
Open drain is very convenient for interfacing with lower voltage logic, for example, or if there are multiple things that might be driving that same wire (for example, I2C is open drain) - if it was push-pull, they'd fight eachother.
In your application it probably doesn't make any difference.
Two or more open drain or open collector outputs can be or'd together, so that any one (or more than one) can pull the output low. With "regular" outputs you can't connect multiple outputs together because if one output goes low and the other goes high, you get get excessive current.
Also, depending on the chip you may be able to connect a higher voltage to the open drain or open collector's pull-up. For example, a chip with a 5V power supply might be able to handle 12V or 15V at it's output.
For driving a FET push-pull is better (assuming the voltage is sufficient to drive the gate).
Thanks very much!
