OpenPyro Transmitter with existing receivers
Hey,
I found OpenPyro for arduino few days ago, but I have some questions about creating a transmitter for existing receivers of my firework firing system. I want to make a transmitter with arduino that I can hook up on my computer and that I can use PyroIgnitionControl software to ignite fireworks.
I currently have this system here:
Does someone can give me more information about this? Creating a new transmitter for exiting receivers with OpenPyro and that work with software as PyroIgnitionControl?
(Computer with PyroIgnitionControl software on it -> Arduino transmitter -> existing receivers -> igniting fireworks)
Thanks in advance!
Regards,
Jordyvc
Please post a link to the system you have, e.g even if its a link to alibaba.com
Looking at onenpyro they have not posted any updates to google code since 2012 so you would have to deduce that the project wasn't that active.
Re your current system.
As it looks like its a closed commercial project, you would probably need to reverse engineer it's data communications.
I'd recommend that you carefully take the remote control transmitter apart and see what ICs it uses, there are several standard ICs used for remote control switches, however you'd imagine that a system to control fireworks would need good security, however as it looks like a budget system, it may just be a normal 433Mhz or 315mhz system using a standard ic
If there are markings on the transmitter e.g. 433 or 315. Compare the transmitter with pictures of the modules for sale on eBay etc, to see if you can determine if its a simple AM transmitter of whether its a special FM transmitter of some kind.
It may however operate on 2.4ghz which is a different can of worms
Another slightly hacks option is to attach wires to the buttons on the existing remote. Someone's you can put a transistor in place of a button and control the transistor with the Arduino, or worst case use reed relays
Thanks for your reply!
I have seen this video on youtube: OpenPyro Demo - YouTube
And at the beginning they where using the same receiver as I have. Would it just be 433MHz? Here is the link to my firework system.
Thanks in advance!
//edit: Just found that these receivers are working on 433MHz.
If you know the OpenPyro stuff works with your existing hardware, as demonstrated in the YouTube video, then all you need to do is to build the OpenPyro hardware and download an use / modify their firmware
Re: Transmitter module
If you look in the project downloads
https://openpyro.googlecode.com/files/OpenPyro_v0.3.zip
Open the Transmitter.png in the OpenPyro\Electronic circuit\OpenPyro_Transmitter
You'll see that the transmitter unit is this one
It looks like its a normal AM TX on 433, but I'm not sure what the SAW bit means.
I'm a bit confused now however about what you want to do.
@JohnLincoln
I suspect there are other issues with a system like this...
The transmitter appears to be a normal AM 433 Mhz unit, and false positives are fairly common
Looking at the code it seems to be using virtual wire, which uses CRC but I'd still be quite concerned about using AM on 433 as its a very noisy band.
I'm not sure what the commercial systems use, but I dount its 433Mhz Am, probably frequency hopping 2.4Ghz with some sort of
Send / Request Confirmation / Confirm system where the receiver unit queries the sender to confirm that it has received the command to fire etc
Hmm, okay.. I was think to do this system wired and make my own receivers/ignitors then. Someone an idea how to connect everything?
Thanks in advance!
