Optical Encoder Problem
Hello,
I am trying to read the data off of two US Digital encoders. These encoders are attached to two motors with back shafts on a large robot that I am planning to enter into the Robo-Magellan. The data comes in properly for the left encoder, but not the right one. Meaning, no data comes in from the right encoder when I turn it. Also, the data for the right encoder is almost, but not quite, the same as that for the left encoder (the one I am turning). The right encoder should not be communicating with the left encoder, instead it should show its own data in the serial window. In the case when you turn the left wheel there should be nothing showing for the right wheel.
I have been working on this for hours, so I am hoping you guys can help me.
Thanks!
Here is a picture of my robot (at the moment):
Here is the link to the encoder's product page:
Here is my code:
volatile long RightDistance = 0;
volatile long LeftDistance = 0;
long PreviousLeftDistance = 0;
long PreviousRightDistance = 0;
// connect right encoder wire A to pin 2
#define RightEncoderPinA 18
// connect left encoder wire A to pin 3
#define LeftEncoderPinA 19
// connect right encoder wire B to pin 13
#define RightEncoderPinB 50
//connect left encoder wire B to pin 14
#define LeftEncoderPinB 51
#define RightEncoderInterupt 5
#define LeftEncoderInterupt 4
    Serial.begin(9600);  // open the serial port at 9600 bps
    attachInterrupt(RightEncoderInterupt, RightEncoderISR, CHANGE); // connect encoder wire A to pin 5
    attachInterrupt(LeftEncoderInterupt, LeftEncoderISR, CHANGE);   // connect encoder wire A to pin 4
    pinMode(RightEncoderPinA, INPUT);  // set the pin to input
    pinMode(RightEncoderPinB, INPUT);  // set the pin to input
    pinMode(LeftEncoderPinA, INPUT);   // set the pin to input
    pinMode(LeftEncoderPinB, INPUT);   // set the pin to input
  if ((RightDistance != PreviousRightDistance) | (LeftDistance != PreviousLeftDistance))
    Serial.print(" Right ");
    Serial.print(RightDistance);
    Serial.print(" Left ");
    Serial.print(LeftDistance);
    Serial.println("");
    //delay(100);
  PreviousLeftDistance = LeftDistance;
  PreviousRightDistance = RightDistance;
void RightEncoderISR()
  if (RightEncoderPinA == RightEncoderPinB)
      RightDistance--;
      RightDistance++;
void LeftEncoderISR()
  if (LeftEncoderPinA == LeftEncoderPinB)
      LeftDistance--;
      LeftDistance++;
I am new to Arduino, but should the interrupts be 0 and 1. (on pins 2 and 3)
#define RightEncoderInterupt 0
#define LeftEncoderInterupt 1
This part is also confusing to me. Should it be:
#define RightEncoderPinA 2
#define LeftEncoderPinA 3
#define RightEncoderPinB 13
#define LeftEncoderPinB 14
What Arduino are you using?
I am using is the Arduino Mega which has the two A pins on the encoders are connected to pins digital pins 18 and 19, and the two B pins on the encoders are connected to digital pins 50 and 51.
Here is the code again, but with the comments updated (the color might make it easier to read):
#define RightEncoderPinA 18 // connect right encoder wire A to pin 2
#define LeftEncoderPinA 19 // connect left encoder wire A to pin 3
#define RightEncoderPinB 50 // connect right encoder wire B to pin 13
#define LeftEncoderPinB 51 //connect left encoder wire B to pin 14
#define RightEncoderInterupt 5 //the interupt number for the right encoder
#define LeftEncoderInterupt 4 //the interupt number for the left encoder
Serial.begin(9600); // open the serial port at 9600 bps:
attachInterrupt(RightEncoderInterupt, RightEncoderISR, CHANGE); // connect encoder wire A to pin 5 (RightEncoderInterupt)
attachInterrupt(LeftEncoderInterupt, LeftEncoderISR, CHANGE); // connect encoder wire A to pin 4 (LeftEnocderInterupt)
pinMode(RightEncoderPinA, INPUT); // set the RightEncoderPinA to input
pinMode(RightEncoderPinB, INPUT); // set the RightEncoderPinB to input
pinMode(LeftEncoderPinA, INPUT); // set the LeftEncoderPinA to input
pinMode(LeftEncoderPinB, INPUT); // set the LeftEncoderPinB to input
if ((RightDistance != PreviousRightDistance) | (LeftDistance != PreviousLeftDistance)) //this makes the distance print only when it changes
Serial.print(RightDistance); //print the RightDistance
Serial.print(LeftDistance); //print the RightDistance
Serial.println("");
//the logic for the right encoder
RightDistance--;
RightDistance++;
//the logic for the left encoder
LeftDistance--;
LeftDistance++;
I too at first thought you had the interrupt numbers/pin numbers wrong, but after some references I think you do have that correct.
Why don't don't you just swap the two channel A wires and see if the problem moves. If it stays the same you probably have something wrong in the code, if the problem moves then it's most likely wiring/external component problem.
Lefty
I figured it out!
It was just some noise caused by a lack of a capacitor across the motor leads and a bad jumper cable.
Thanks for all of your help!
