Used mouse rotary encoder
Hi there !
I am currently doing experiments with a salvaged mouse rotary encoder.
the problem i’m facing isn’t from the code itself, ‘cos i tried a bunch of ‘em i’ve found on internet
the problem is, this encoder is quite old, it come from a mouse i’ve been using for a while now, so of course it is used, and the contacts A and B aren’t tight anymore.
here’s an example of code i used to make it work (not my code !) :
#define encoder0PinA 2
#define encoder0PinB 3
#define encoder0Btn 4
int encoder0Pos = 0;
  pinMode(encoder0PinA, INPUT_PULLUP);
  pinMode(encoder0PinB, INPUT_PULLUP);
  pinMode(encoder0Btn, INPUT_PULLUP);
  attachInterrupt(0, doEncoder, CHANGE);
int valRotary,lastValRotary;
  int btn = digitalRead(encoder0Btn);
  Serial.print(btn);
  Serial.print(" ");
  Serial.print(valRotary);
  if(valRotary>lastValRotary)
	Serial.print("  CW");
  if(valRotary  {
	Serial.print("  CCW");
  lastValRotary = valRotary;
  Serial.println(" ");
  delay(250);
void doEncoder()
  if (digitalRead(encoder0PinA) == digitalRead(encoder0PinB))
	encoder0Pos++;
	encoder0Pos--;
  valRotary = encoder0Pos/2.5;
and using it with a new rotary encoder (not from a mouse), it works very well.
But with the old mouse encoder here’s what happens (on the serial monitor) :
rotating in one way, i get “rotating clockwise”. Good, it works.
now the other way, i get “rotating counter-clockwise” then “clockwise” the “counter..” etc.
does anyone knows if i can compensate in a way or an other the fact the this component is used ? i already tried using a delay, it doesn’t change anything.
Hi, can you please post an oscillogram of the A and B waveforms, both rotating CW and CCW?
You could clean it with contact cleaner.
Also add few millisec debounce to your doEncoder.
And don't use decimal value to scale valRotary (which is int).
Hth:
https://community.element14.com/members-area/personalblogs/b/blog/posts/rotary-encoders---part-3-capturing-input-on-an-arduino
https://community.element14.com/members-area/personalblogs/b/blog/posts/rotary-encoders---part-1-electronics
hey ! i’ll do that as soon as i can
Couldn’t it be that int.0 is related to digital pin 2? Is your board an Uno?
The use of digitalPinToInterrupt() is recommend when using attachInterrupt().
yes it is.
btw here’s the real code i used to make my tests (even though the one i’ve shown in my first post is quite similar) :
int pinA = 6;
int pinB = 7;
int encoderPosCount= 0;
int pinAlast;
int aVal;
boolean bCW;
void setup{
  //SET pinA and pinB and input
  pinMode(pinA, INPUT_PULLUP);
  pinMode(pinB, INPUT_PULLUP);
  pinALast = digitalRead(pinA);
  Serial.println("BEGIN");
  aVal= digitalRead(pinA);
  if(aVal |=pinAlast)
    if(digitalRead(pinB) != aVal) //rotatingClockwise
      encoderPosCount ++;
      bCW = true;
      bCW = false
      encoderPosCount --;
    if(bCW)
      Serial.println("rotate clockwise");
      Serial.println("rotate counter-clockwise");
    Serial.print("encoder count: ");
    Serial.println(encodePosCount);
  pinAlast = aVal;
Did you intend this to be aVal |= pinAlast (OR EQ) or aVal != pinAlast (NOT EQ)?
Also... this...
needs an ending semi-colon.
And this...
needs an open/close parenthesis...
