Optical encoder: read engine speed
Hello,
I have been working on finding the RPM of a motor using an optical encoder. I have a motor "maxon DC motor 9V 118742" connected to an encoder "Avago HEDS 5540#A02" by which I would need to know the number of revolutions the engine makes. I have an "Arduino Uno" and turning between the forum I understand how to make connections, but I have not found a code that worked. Could you help me write a code that works? Thank you.
15-135-EN.pdf (444 KB)
AV02-1046EN_DS_HEDM-55xx_2014-11-20.pdf (462 KB)
Well you haven't presented any of the sketches you've already tried... Perhaps you should show us
one that you've tried so we can fix it or work out why.
I have tried several codes, including this one that I found here on the forum. But this does not always work well.
[code]
int tick = 0;
int oldIn = 0;
int currentIn = 0;
float mins = 0;
float timeMillis = 0;
float oldTimeMillis = 0;
float rpmReturn = 0;
float rpmPrint;
  // attachInterrupt(digitalPinToInterrupt(2), readRPM, CHANGE);
  pinMode(2, INPUT);
  currentIn = digitalRead(2);
  if(currentIn != oldIn){
    tick++;
  timeMillis = millis();
  if (tick >= 360){
    tick = 0;
    rpmPrint = rpm();
    Serial.println(rpmPrint);
    oldTimeMillis = timeMillis;
  oldIn = currentIn;
void readRPM(){
  tick++;
float rpm() {
  timeMillis = timeMillis - oldTimeMillis;
  mins = (timeMillis / 1000) / 60;
  rpmReturn = 1/mins;
  return rpmReturn;
[/code]
You should be using the external interrupt for this application.
You have the 5540 model which has an index pulse on its pin #2. If you connect that to pin 2 or 3 of the UNO you should be able to read the count with an external interrupt.
There are many projects for tachometers and speedometers to be found.
This might get you started
http://playground.arduino.cc/Main/ReadingRPM
With the motor you have the rpm should be high enough that simply counting the pulses over a fixed period of time might be accurate enough for your application. Here's very simple code which counts pulses for one second.
volatile unsigned long  count = 0;
unsigned long copyCount = 0;
unsigned long lastRead = 0;
unsigned long interval = 1000;//one second
  Serial.println("start...");
  pinMode(2,INPUT_PULLUP);
  attachInterrupt(0, isrCount, RISING); //interrupt signal to pin 2
  if (millis() - lastRead >= interval) //read interrupt count every second
    lastRead  += interval;
    // disable interrupts,make copy of count,reenable interrupts
    noInterrupts();
    copyCount = count;
    count = 0;
    interrupts();
    Serial.println(copyCount);
void isrCount()
  count++;
Thank you cattledog!! With your code rotating by hand the motor I visualize the number of turns (which should be) corrected on the serial monitor. I will test this code when I provide a specific voltage value to the motor at the laboratory.
One last question: Do you know why when I turn from vertical position in the horizontal position the motor the value of speed varies by 2-3 orders of magnitude?
adanilo90:
No it won't its not correct. The 'tick' variable should be declared volatile, and should be accessed from
the main sketch with interrupts disabled:
  noInterrupts () ;
  if (tick >= 360)    // read and
    tick = 0;            // write access to tick is protected.
    interrupts () ;
    rpmPrint = rpm();
    interrupts () ;   // mustn't forget to enable interrupts again whatever the if condition.
MarkT:
  noInterrupts () ;
    interrupts () ;
    rpmPrint = rpm();
Hi MarkT, I've tried to implement your correction, but there is something wrong in the code and I do not understand where. The complete code is below:
volatile int tick = 0;
int oldIn = 0;
int currentIn = 0;
float mins = 0;
float rpmPrint;
  pinMode(2, INPUT);
    tick++;
  noInterrupts () ;
    interrupts () ;
    rpmPrint = rpm();
  oldIn = currentIn;
void readRPM(){
  tick++;
float rpm() {
  rpmReturn = 1/mins;
  return rpmReturn;
cattledog:
Arduino Playground - HomePage
    noInterrupts();
    copyCount = count;
    count = 0;
    interrupts();
void isrCount()
  count++;
Hi cattledog, I tried your code by connecting the motor to a voltage source and giving them input values from 2 to 5 volts, but I got completely the wrong values. Do you know why?
I do not think you are connected to the correct pins for GND(1), index(2), and Vcc(4). See figure 1 of the data sheet. http://docs.avagotech.com/docs/AV02-1046EN
cattledog:
Yes you are right! I've made the right connection and now everything works! Thank you so much.
i need the right connection of this encoder after editing
I do not understand what "after editing" means.
If you are trying to read the index pulse?
encoder pin1 to arduino ground
encoder pin4 to arduino 5volts
encoder pin2 to arduino external interrupt pin
If you are trying to read quadrature it will be different.
The data sheet is pretty simple. What are you having difficulty understanding?
adanilo90:
i mean this right connection , but thanks i saw the data sheet and apply it in my encoder .
i have another question please, i try to control my IAC and i don't know what is the suitable driver to connect with it and depending on what?
if any one know the electrical signal cable of IAC ( idle air control ) connect with driver motor , did you know what is the type of driver and it's connection with IAC and thanks :smiley:
