Original Yun issues
Edited the post to correct some references and add info :
I purchased a couple Yun a few years ago and gave up using them....I am trying again but I think I am running into the same issues - flaky wifi.
Basically the White USB comes on and not the Blue WiFI - the ArduinoYun-XXXXXXXXXXXX shows up as a wifi host - (with no blue light) - when you try to log on - the White USB Light goes out.
I can "reset" the Yun, and get the WiFi hostname to show up, I can connect, but but have no luck wiht http://arduino.local, . If I go to the IP 192.168.240.1, I can access the Yun, but when I put in the default password "arduino" the Wifi shuts off and the white LED goes out.
After a few minutes the Wifi host shows up and the white led comes back on - and you can get to the initial screen, but now it will not even go to the password screen.
30 Sec hold of the WiFi Rst - gets the wifi to come back on - try to connect, wifi light goes out.
It never seems to be consistent.
Is it dead / a lost cause?
I can load sketched via USB cable connection to the computer.
I was able to load YunSerialTerminal and get a dump after the reset - needs to be two posts.
U-Boot 1.1.4-dirty (Apr 10 2014 - 15:12:15)
Arduino Yun (ar9331) U-boot
DRAM: 64 MB
Top of RAM usable for U-Boot at: 84000000
Reserving 142k for U-Boot at: 83fdc000
Reserving 192k for malloc() at: 83fac000
Reserving 44 Bytes for Board Info at: 83fabfd4
Reserving 36 Bytes for Global Data at: 83fabfb0
Reserving 128k for boot params() at: 83f8bfb0
Stack Pointer at: 83f8bf98
Now running in RAM - U-Boot at: 83fdc000
Flash Manuf Id 0xef, DeviceId0 0x40, DeviceId1 0x18
flash size 16777216, sector count = 256
Flash: 16 MB
Using default environment
In: serial
Out: serial
Err: serial
Net: ag7240_enet_initialize...
No valid address in Flash. Using fixed address
: cfg1 0x5 cfg2 0x7114
eth0: 00:03:7f:09:0b:ad
eth0 up
: cfg1 0xf cfg2 0x7214
eth1: 00:03:7f:09:0b:ad
athrs26_reg_init_lan
ATHRS26: resetting s26
ATHRS26: s26 reset done
eth1 up
eth0, eth1
Hit any key to stop autoboot: 4  3  2  1  0
Booting image at 9fea0000 ...
Image Name: MIPS OpenWrt Linux-3.3.8
Created: 2014-11-14 8:00:46 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1185448 Bytes = 1.1 MB
Load Address: 80060000
Entry Point: 80060000
Verifying Checksum at 0x9fea0040 ...OK
Uncompressing Kernel Image ... OK
No initrd
Transferring control to Linux (at address 80060000) ...
Giving linux memsize in bytes, 67108864
Starting kernel ...
[ 0.000000] Linux version 3.3.8 (jenkins@jenkins) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #1 Fri Nov 14 08:57:34 CET 2014
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[ 0.000000] SoC: Atheros AR9330 rev 1
[ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 04000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Zone PFN ranges:
[ 0.000000] Normal 0x00000000 -> 0x00004000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00004000
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: board=Yun console=ttyATH0,250000 mtdparts=spi0.0:256k(u-boot)ro,64k(u-boot-env)ro,14656k(rootfs),1280k(kernel),64k(nvram),64k(art),15936k@0x50000(firmware) rootfstype=squashfs,jffs2 noinitrd
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 60936k/65536k available (2565k kernel code, 4600k reserved, 650k data, 180k init, 0k highmem)
[ 0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:51
[ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[ 0.080000] pid_max: default: 32768 minimum: 301
[ 0.080000] Mount-cache hash table entries: 512
[ 0.080000] NET: Registered protocol family 16
[ 0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
[ 0.090000] MIPS: machine is Arduino Yun
[ 0.530000] Setting DogStick2 GPIO
[ 0.550000] bio: create slab at 0
[ 0.550000] SCSI subsystem initialized
[ 0.560000] usbcore: registered new interface driver usbfs
[ 0.560000] usbcore: registered new interface driver hub
[ 0.560000] usbcore: registered new device driver usb
[ 0.570000] Switching to clocksource MIPS
[ 0.570000] NET: Registered protocol family 2
[ 0.570000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.580000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.580000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.580000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.580000] TCP reno registered
[ 0.580000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.590000] NET: Registered protocol family 1
[ 0.610000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.610000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.620000] msgmni has been set to 119
[ 0.620000] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
[ 0.620000] io scheduler noop registered
[ 0.630000] io scheduler deadline registered (default)
[ 0.630000] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.640000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) i{ a AR933X UART
[ 0.640000] console [ttyATH0] enabled, bootconsole disabled
[ 0.650000] m25p80 spi0.0: found w25q128, expected m25p80
[ 0.650000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.650000] 7 cmdlinepart partitions found on MTD device spi0.0
[ 0.660000] Creating 7 MTD partitions on "spi0.0":
[ 0.660000] 0x000000000000-0x000000040000 : "u-boot"
[ 0.660000] 0x000000040000-0x000000050000 : "u-boot-env"
[ 0.670000] 0x000000050000-0x000000ea0000 : "rootfs"
[ 0.670000] mtd: partition "rootfs" set to be root filesystem
[ 0.670000] mtd: partition "rootfs_data" created automatically, ofs=7B0000, len=6F0000
[ 0.680000] 0x0000007b0000-0x000000ea0000 : "rootfs_data"
[ 0.680000] 0x000000ea0000-0x000000fe0000 : "kernel"
[ 0.680000] 0x000000fe0000-0x000000ff0000 : "nvram"
[ 0.690000] 0x000000ff0000-0x000001000000 : "art"
[ 0.690000] 0x000000050000-0x000000fe0000 : "firmware"
[ 0.710000] ag71xx_mdio: probed
[ 0.720000] eth0: Atheros AG71xx at 0xba000000, irq 5
[ 1.270000] eth0: Found an AR7240/AR9330 built-in switch
[ 2.300000] eth1: Atheros AG71xx at 0xb9000000, irq 4
[ 2.850000] ag71xx ag71xx.0: eth1: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
