Overwrite File on Esp8266 using SdCard Module
Code fine When is use O_TRUNC on Arduino Uno, but when i upload it on Wemos D1 R1. The error always say that O_TRUNC / O_READ are not declared.
ReadWrite_v2.ino (639 Bytes)
It looks like you will have to delete the file if it exists and open it again to write to it
I need that file for backup data, when the device shut down then it turn on again, it wont start from 0 again.
Doesn't O_TRUNC truncate the file to zero bytes in length, effectively deleting its contents ?
yes when i use O_TRUNC for overwrite data using arduino, it works fine. but when i use O_TRUNC on esp8266 always error.
esp8266\2.6.3\libraries\ESP8266SdFat\src/FatLib/FatApiConstants.h:81:15: note: 'sdfat::O_TRUNC'
const uint8_t O_TRUNC = 0X10;
shiemi1998:
So if you could us O_TRUNC it would delete the file
I am not clear when and why you want to us O_TRUNC. Perhaps if you posted a full program it would help
#include <SPI.h>
#include <SD.h>
#define CS_PIN D8
File myFile;
String a;
int b;
while(!SD.begin(CS_PIN)){
Serial.println("Error Finding SdCard");
if (SD.begin(CS_PIN)){
Serial.println("SdCard Found");
myFile = SD.open("test.txt", FILE_READ | O_READ);
if (!myFile.available()){
Serial.println("File doesnt exists");
Serial.println("Reading File");
a = myFile.read();
Serial.println(a);
myFile = SD.open("test.txt", FILE_WRITE | O_TRUNC);
if (b != 2) {
b = b + 1;
myFile.print(b);
Serial.println(b);
b = 0;
myFile.print(b);
Serial.println(b);
Now I am completely confused. Why would you open the file each time through loop() and trancate its length to zero when you do ?
Please explain exactly what you want to do
if i didnt trancate it, it will append. like on node-red when want write to file there is 2 options. 1. append, 2. overwrite.
i want write data on a file, when i write data again on that file.
i already try to delete the file, then write again. but when i restart wemos and read that file. there is no file on sd card.
shiemi1998:
Post the code that does that
#include <SD.h>
#include <Wire.h>
#include <SPI.h>
#include <ModbusTCPSlave.h>
#include <ESP8266WiFi.h>
#define CS_PIN D8
File myFile;
const char* ssid = "test";
const char* password = "pepsodent";
ModbusTCPSlave modbus;
int data;
long int y, z, b;
String x, c;
float a;
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
modbus.begin(ssid, password);
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Please Wait");
Serial.println("");
WiFi.begin(ssid, password);
Serial.print("WiFi : ");
Serial.print(ssid);
Serial.println(" are not available");
if (WiFi.status() == WL_CONNECTED) {
Serial.print("Your IP Address is : ");
while (!SD.begin(CS_PIN)) {
Serial.println("SDCard initialization failed!");
if (SD.begin(CS_PIN)) {
Serial.println("SDCard Initialization Done");
myFile = SD.open("BACKUP.TXT", FILE_READ);
if (!myFile.available()) {
Serial.println("There is no Backup File");
while (myFile.available()) {
if (x == "") {
Serial.print("Checking Backup File");
Serial.write(".");
Serial.write(".");
Serial.write(".");
Serial.println("");
String READ = myFile.readStringUntil('\n');
x = READ;
myFile.close();
Serial.println("Your Last Energy Usage : " + x + " kWh");
Serial.println("Backup File Done");
lcd.clear();
lcd.print("All Intialize Done");
lcd.clear();
modbus.Run();
if (Serial.available() > 0)
if (x != "") {
x = READ;
myFile.close();
y = x.toInt();
data = Serial.read();
y = y + data;
b = y;
Serial.println(b);
//SD.remove("BACKUP.TXT");
y = y + data;
b = y;
Serial.println(b);
c = String(b);
Serial.println("?");
myFile.print(c);
myFile.close();
modbus.MBHoldingRegister[0] = 1;
modbus.MBHoldingRegister[1] = b;
if (Secs == 1) {
x = READ;
y = x.toInt();
myFile.close();
a = y / 60;
Serial.println(a);
modbus.MBHoldingRegister[2] = a;
lcd.print(a);
lcd.clear();
b = 0;
c = "";
//return;
how?
It would help considerably if you posted your code as advised in Read this before posting a programming question
it doenst help anything with O_TRUNC problem on esp8266
shiemi1998:
No, but it will help others to download and examine your code but feel free to ignore the advice.
I am afraid that I can offer no more help
this the error
