Oxygen level sensor for room
Hi folks!
I have teensy 3.0 device which I want to use for some projects.
I'm living in Asia, currently in Thailand, Bangkok.
Its pretty hot and dry, so I need to measure oxygen level in my room using some sensor and teensy board.
Basically I need to find sensor and make it work with teensy board...
Any recommendations are highly appreciated!
So, what have you done to first find your sensor. After finding, then you can begin to make it work.
A Google search finds this:
Unless you have no ventilation, as it’s dry , the Oxygen level won’t change . Humidity will affect it , heat doesn’t .
If you’ve a ventilation problem , might be better to measure CO2 ????
What is the issue you want to fix ?
hammy,
Yes, there is humidity change in range 40-80, based on outdoor weather and my AC usage
yes, probably I want to measure both CO2 and O2
groundFungus, yes, i searched for that too, but that one looks quite expensive
Paul_KD7HB, that's a good question, I ve searched local online stores (lazada/shopee), aliexpress, ebay
looking for something less then 50$, best in 10-20$ price range, which gonna work with my teensy board
I feel sick sometimes (I'm European living in Tropics) and I believe it caused by low oxygen level, which differs from time to time...
need to measure it
O2 will be proportional to CO2. Just saying.
For CO2 level measurement, you can use MQ-135. It can also be used to calculate AQI for IoT and smart irrigation projects.
For oxygen, you can choose from Gravity: I2C Oxygen Sensor or OOM202 Oxygen Sensor.
