Hi everyone,
I'm about to build out a bunch of these:
They're built off of these:
There is one wire that will join the negative line back to Vo by spanning across multiple lines, but only getting soldered at lines 2, 4, and 7 (reading left to right). To avoid short-circuiting the line on the other ones it'll pass over, can I "paint" something onto the other foil areas just below the wire that I'll run. I know there's liquid insulation out there, but I don't need a ton of the stuff, so I'm wondering if there's other household options. I have acrylic hobby paints, latex wall paint handy... would those work?
If it matters, source power is 12v, about 1.5amps.
Regular silione or caulk works for me, just pump some on it while the wires not touching and a day later its dry and depending what you get soft and flexible but very protective
Depending on what you want your finished product to look like, you could make say a square mold around the components as well and pump it full of silicone which would prevent any of those long leads from accidently touching and a cool plug in cube is always pretty nice looking lol
Just a follow up on an old thread, in case future searchers stumble across it. In the end, I tested some hobby/home paints, and wasn't happy with easily they rubbed off the surface.
Rokkit had a great idea too.
In the end though, drilled through the PCB with a micro-bit, and ran the wire along the back of the board, which is blank. A quick hit of solder on the front side, and everything is connected. Definitely not the first time this has been done, I'm sure, but it felt like a genius moment for me!
Thanks again to everyone for their hints and tips.
