Hi all, I've been working on a project that required to use this encoder. Any idea is there any Arduino library for this encoder? Can't seem to find it online.
Brand: Panasonic
Type: EVWAE/EVWAD
datasheet
Brand: Panasonic
Type: EVWAE/EVWAD
datasheet
You don't need a library.
Connect pin1 to arduino ground.
Connect pin3 to arduino 5V
Conncet pin2 to arduino A0
use analogRead(A0) to read the position.
The value will range from 0 to 1023, 512 is in the middle
0 is 0 degrees, 512 is 171.5 degrees, 1023 is 343 degrees
You can use map to get degrees
deg = map(analog_ read_value, 0, 1023, 0, 343)
Can you provide me with a simple code to test if my potentiometer is working correctly? Now, the value I got is fluctuating. Thank you
Show how you have it connected to the Arduino
Hi, @b4bygirl
Welcome to the forum.
Can you please tell us your electronics, programming, arduino, hardware experience?
Is this a school/college/university project?
What is the application of your project?
Thanks.. Tom..
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
delay(200); // delay in between reads for stability
